7inch Frame Selection - FR7 5.1 vs AOS Falcon 7
Question
The local mail office seems to have lost my SourceOnce Deadcat 7inch frame, that I selected for my first MidRange/LongRange 7inch build and now I can take the opportunity to get other frame.
I was about to get the FR7 frame, buy now the AOS Falcon 7 is released and I am curious about the frame. It seems heavier that the FR7 v5.1, but stiffer, but I do not know how relevant it is for this build. Any thoughts or alternatives?
I don't have a 7", but I have seen a lot of people like the GepRC Crocodile 7"
https://geprc.com/product/gep-lc7hd-frame/
Or the Mark4 7" (I Have the 5" Mark4 and love it)
https://geprc.com/product/gep-mark4-hd7-...rame-kits/
FalconRad FPV (check him on youtube) designed the AOS Falcon 7 frame.
He mentioned in his videos that he did some vibration analysis and tests on the frame and he has flight videos to show the flight quality.
He seems to have tested a few combinations of parts that he recommends if you want to build it.
Getting the tune on a 7” can be tricky and so if you follow the designers build instructions you know you will get it right.
8mm arms on a 275mm 7" is overkill.
7" is just dipping toes of "big quad" and only first step away from Betaflight 5" defaults.
5 ways you might get Jello/vibrations.
1. Mark4 is only 5mm and 295mm..6mm preffered.. but also mportantly stiff "sandwich" to hold arms.
2. You toss 7" prop on your old 2207 motor. 7" props are much heavier and difficult to accelerate. For serious acro or strong wind resiliance consider FPVCycle31xx motor.
3. Soft mount = good. right? It lowers amplitude but springy material will also lower the vibration frequency = bad. On 7" makes little difference but >10" its probably better to hard mount.
4. Dont forget the lowESR. On 3" you can use pretty much anything. Any 220uF will do. Heck most people fly without it. On 5" it makes a difference.. but even more on 7". Rapid changes in ESC /motor-rpm create huge spikes and feedback as "noise".
5. I do this 10-20x a week. You crash a 3" toothpick. Bend prop. Keep flying. Heck half the time you dont even bother to bend it back.. and ignore the jitters.
On 7" or bigger, prop balance is even more important.
Well, things got simpler for me... the fr7 is on banggood and Its way cheaper for me than buying from cncmadness.
consider project 399 superg plus - this is really great frame imho also Wink
I have 2 BQE bandalero 7” and love them both. One is long range 20 min on a 3300 5s with 4mm arms and my other one is for ripping around with some crazy brother hobby motors on 6mm arms.
FWIW I have a AOS Falcon 7 and love it. It's video always come back smooth with stabilization off on my gopro8. A bit heavier, but it covers ground quick and flies well. I also have a Super G Plus that I like to cruise around fast and the Falcon is honestly smoother.
  frame and props for XING-E PRO 2306 6S fra_gra 5 764 20-Jun-2023, 04:26 PM
Last Post: romangpro
Question Help INAV - Apparently random current spikes on 7inch moserello 0 434 30-Jan-2023, 02:57 PM
Last Post: moserello
  AOS 7 Build Haggy38 7 1,060 28-Sep-2022, 03:55 PM
  Build Wobbling/Twitching in straight flight with AOS LR 5 veiovis 6 797 19-Sep-2022, 05:41 AM
Last Post: StSV
  My 7" long range build on alien clone frame Frizi 4 961 26-Mar-2022, 02:19 AM
