31-May-2020, 01:53 AM (This post was last modified: 31-May-2020, 02:03 AM by hugnosed_bat.)
old and used parts:
- diatone mamba f4 20x20mm
- diatone mamba 4in1 20a
- akk 20x20mm vtx, dont know the model, has a builtin mic and able to provide 600mw (as space is needed, a nano32 would be nice)
- eos turbo (to change after settup)
- t-motor f20 II 3250kv
- modded baseplate of airblade uav eclair 3“ frame
- fs-a8 ibus receiver (to change, looking for some space)
- 20x20mm canopy, a design found on thingiverse
- rubycon 25v 470uf and a changx 25v 470uf, this combinations as a try, i will remove one after a few flights and an impression
- for the moment some dalprop 4040x3 and 4045x3, i need some hq4043
there are some gemfan 4023x3 on the way.
- crappy lipo strap
- griptape for the lipo
will be used with 650mah 4s, probably 850mah 4s lipos
bf4.2 rc2
wasnt allready on the scale, should be about 100g, hopefully less. a true ultralight, should be my lowest weight 4inch.
- crappy lipo strap
bf4.2 rc2
