Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 This is a very cool build! Thanks for sharing with us. Looking forward to some in-flight videos. • Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 11-Jan-2020, 02:12 PM (This post was last modified: 11-Jan-2020, 02:13 PM by sim_tcr.) I did an indoor hover test. Hover throttle percentage starts from 70% and I got around 13min flight time. In the end I did not have any more movement available for throttle. But there was still juice in the battery. It was 6.8V (while quad on air). I know I could reduce it down to 6.2V at least. Is there any adjustment I can do in INAV or x9 lite to adjust throttle, so that my hover throttle percentage come down? So I have more throttle stick deflection available? # get min_check min_check = 1020 Allowed range: 1000 - 2000 # get max_throttle max_throttle = 1980 Allowed range: 1000 - 2000 • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 As your voltage drops, so will your rpm's. I'm curious if you might want to go to a higher KV motor instead, then do a throttle limit. • Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 (11-Jan-2020, 05:23 PM)sloscotty Wrote: As your voltage drops, so will your rpm's. I'm curious if you might want to go to a higher KV motor instead, then do a throttle limit. I had initially tried with 1104 7000kv motor. Flight time was around 10min. But hover throttle was between 60% and 70%. What is throttle limit? And how is it done in INAV? • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 You may not need a throttle limit if you go to say 6000kv of the same motor. Bardwell has a video on throttle limit in BetaFlight. Not sure about iNav. I just know that the 4500kv is really made for 3-4s. The 6000kv is for 2-3s. EngineerX on youtube doesn't provide thrust data on 2s on the Emax RS4500. With the 6000kv on 2s with 3020 2-blade he gets 215gr thrust at 9.5a. (Older version of that motor though). Don't know how that would compare with the 4500kv. Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 11-Jan-2020, 06:16 PM (This post was last modified: 11-Jan-2020, 06:17 PM by kaitylynn.) SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 1+ throttle curve solve the throttle resolution on a 1s build with low power to weight ratio for me. high kv would solve the issue, 4500kv on 2s would have max rpm of 37800 in theory - at 8,4v. on 6v there would be 27000rpm in theory. not much on 3“. i beleive a reason about performance and efficiency would be a 4“ blade. as the motor can handle 4s on 3inch, this should work well on 2s with a light 4inch blade. 15a esc should be fine aswell. https://m.banggood.com/2-Pairs-HQProp-T4...90493.html lower weight would help aswell. i flew 1106 3800kv motors on 2s with good results for flights in tight spaces, but my was about 90g and with a 450mah2s lipo lightweight in comparison. i got about 5minutes flytime. it was on a diatone grasshoper 160 frame - a 4inch frame sadly these hq 4025 wasnt available about weight aswell, did you try different battery options? Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 I tried hover test again today with 3000mah 18650 3s pack. now AUW is 277gm. Got 20 minutes+ flight time. Brought down voltage up to 7.5v (air) Definitely flyable till 18 minutes at 70% hover throttle and voltage being 8.7V under 10A current pull. Now hover throttle range is from 55% to 70%. But my goal is AUW under 250gm. With smaller vtx, I could save some 10gm. I still got to shed some 30gm weight. GPS and its mount taking around 15gm. • Posts: 108 Threads: 38 Likes Received: 7 in 4 posts Likes Given: 12 Joined: May 2019 Reputation: 0 (12-Jan-2020, 02:50 PM)sim_tcr Wrote: I tried hover test again today with 3000mah 18650 3s pack. now AUW is 277gm. Got 20 minutes+ flight time. Brought down voltage up to 7.5v (air) Definitely flyable till 18 minutes at 70% hover throttle and voltage being 8.7V under 10A current pull. Now hover throttle range is from 55% to 70%. But my goal is AUW under 250gm. With smaller vtx, I could save some 10gm. I still got to shed some 30gm weight. GPS and its mount taking around 15gm. Nice build,hope you enjoy it. I have a question what antenna do you have installed? THANK YOU • Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 (12-Jan-2020, 04:42 PM)Armandoaulet Wrote: Nice build,hope you enjoy it. I have a question what antenna do you have installed? THANK YOU Rx is normal frsky r-xsr antenna. VTX antenna whip antenna. • Posts: 51 Threads: 12 Likes Received: 23 in 12 posts Likes Given: 1 Joined: Nov 2019 Reputation: 0 Super cool build! I just got all the parts to build something similar, even the 18650 batteries • Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 in attempt to reduce weight, i made another frame with abs plastic mimicking original cf frame. I saved 14gm. So now dry weight 114gm. Arms were bit flexible. Any way I gave it a try with 3s first and 2s next. With 3s, it sounded different, and current draw was also more than when i flown original frame and 3s. And within a minute motors got hot to touch. Did not continue further. Then tried with 2s, it flown ok. same flight time of 13min (original frame and 2s gave same results). Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 Any update flights? You are getting almost double my flight time and am enjoying your build adventure! SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 21-Jan-2020, 02:47 AM (This post was last modified: 21-Jan-2020, 02:48 AM by sim_tcr.) (21-Jan-2020, 02:38 AM)kaitylynn Wrote: Any update flights? You are getting almost double my flight time and am enjoying your build adventure! Yes I could easily get 10min+ on 2s and 15min+ on 3s. With 2s there isn’t much room left with throttle . With 3s that’s improved but weight increased above 250gm. Not sure if I can have a real outdoor flight soon. I don’t have any flying field close to me. I can trying to put a video of indoor hovering. |
