Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 1
0 26-Oct-2019, 05:11 PM (This post was last modified: 26-Oct-2019, 06:03 PM by Sticker.) Hello,
I’m on planning to make a 3 inch quad for freestyle.
What size motors and kv should i use, and how much amp for the 4in1 esc
I planning to use a 4s lipo.
Threads: 1
Likes Received: 1 in 1 posts
Likes Given: 9
0 I did not know anything, so i build a Rotorx Atom 122 with 1408 Geprc 3600kv motors and 20 amp 4in1 esc.
Totally Atomic ? It took some getting used to but is my favorite quad now
Threads: 125
Likes Given: 99
388 13xx-14xx are typically motors for 3 inch. I would go 3500-4100kv. For 3 inch, I like 4100 kv more. 20A should be enough. But you want to check your motors thrust data for amp draw.
Threads: 1
Likes Given: 1
0 Thanks guys, what prop would you recommend?
Threads: 172
Likes Given: 4,752
103 27-Oct-2019, 11:58 AM (This post was last modified: 27-Oct-2019, 11:58 AM by hugnosed_bat.) for freestyle, i guess the hq3030x3 should give good thrust-response, the hq3030x4 even more but topend („and efficiency“) arent that well. i fly and love the hq3030x3, hq3040x3 and my new love for 3inch is the azure3060x3. i would recommend all for a try, every motor have diffrent „benefits“, pared with a personal flystyle make it even more difficult, only trys will give the experience to choose the choosen one ;-)
Threads: 43
Likes Received: 286 in 202 posts
Likes Given: 12
5 I run BrotherHobby T1's, 1407/4100kv on my 3" Gecko. I run Gemfan 3052's and HQ 3x4x3. I seem to get more prop wash with the HQ's, but both do a pretty good job at keeping me out of the trees....
I'm using a Mamba F405 mini mk2 stack with F25 mk2, 25 amp ESC.
Deal
Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench....
