Threads: 61
Likes Received: 1,034 in 747 posts
Likes Given: 98
53 Is it possible to replace the female u.fl connector on the cable side of antennas or is a specialized tool needed for this. I was very clumsy and managed to chop off the ufl connectors on two perfectly good antennas. These female connectors seem very hard to find, unlike the male smd plugs. Has anyone tried replacing these u.fl plugs on the cable-side or know a source for them?
Threads: 125
Likes Given: 99
388 Yes possible. Plenty of video on YT.
Threads: 2
Likes Received: 8 in 8 posts
Likes Given: 2
0 I use a set of Engineer PA09 crimping pliers for those (partially). But you can do it by hand with needle nose pliers, tweezers and good eyesight.
Threads: 61
Likes Given: 98
53 Ok, so the center wire just slips into the connector, not even soldered? I guess I has some old rx antennas I can try and salvage a connector from.
Threads: 2
Likes Given: 2
0 It's not soldered just crimped. You could buy some ready crimped wires and solder the other end. (they are cheap) Would be an easier task than trying to recrimp these connectors.
