not so tiny whoover
[Image: dnoschcl.jpg]
will it give incomplete motor set pleasure?
i like to use: 20a aio / superman 1404 3800kv / broken eclair frame
ideas or video links how i could do the bottom?
how could i mix the 3 motors, like an airplane model is my actual plan. any idea about would be appreciated.
edit: my idea of using a plane model in bf is to get stabilization on yaw, as it should give yaw instability from a single prop i the front
thank you for any help
  • the.ronin
https://github.com/martinbudden/betaflig...s/Mixer.md
i will probably need to di a custom mixed settup
You should be able to select tricoptor mode in betaflight?
  • hugnosed_bat
thank you for the reply
the tricopter configuration to have the single motor in the front wont work, was my idea. but im unsure. did i miss an option to get a layout of the single motor in the front on a tricopter?
i also mentioned about y4, butbit seems it wouldnt work.
as it would only need a stabilization on the yaw axie,i beleive it wont work well.
after add an aio, doesnt get the mix i like, i went for a different try, but im still looking for options.
its actualy hoovering, there is no fc added. a receiver and three single esc, one of them is only able to do 3s, im limited in power at the momemt.
i mixed the two rear motors and set the front motor on a poti.
it works pretty okish but it needs handling improvements. i will need to add a lot of expo to get nice corners and not sure if it will be enough improvement.
im still looking forward to improve it with a gyro stabilization on yaw.
thinking about a gyro for rcplanes or rccars, but stear two motors with that signal didnt get my understanding.
there are benefits for fourmotor-whoovers, but i still like to get it working with incomplete motorsets, its no option.
probably my actual thoughts are wrong, the important bottom part is still a improvisation. probably with better uplift the handling will go better aswell.
i added a plastic bag with hotglue and some holes in it to get uplift. it worked somehow nice on flat ground, or it was sliding nice. i could get it to mouve, but i didnt get enough uplift outside.
its still a project, seems i like to go more deep in it, every ideas would be appreciated.
he starts a bottom-solution at minute 3, i will try to improve the bottom part in this direction.
The easiest solution. Add a 4th motor. Haha.
[Image: Q1erytdl.jpg]
a 4th motor is to easy xD nothing to explore
and i would need to mix two incomplete motorsets to get four motors :-) i realy would like to get a pleasurefull use for parts i wont use on quads; 3motors or 3in1 escs... like banelle s signature; ground is for dead parts xD zombie builds xD
  • the.ronin
i improved it by a near version like in the viedeo on post 5#
one 1404 did burn out, i added an old f20 to the front.
with improved bottom part and a lot expo its going to be very nice :-) ph try im coming for you xD
Sick!!!! Now you got me wanting to make my own lol.
dvr coming soon xD
i added 4inch props to the back, feels better. gave better handling, probably because of the wider wingspan?
there was terribal overstearing first, i set the weight to 40 and the expo to 60 on my taranis, i am able to do beautifull wide corners or thight ones.
i improved the second bottom version, the plastic is a bit more stiff, probably i will do a bottomv3 but first will come the ph try :-)
[Image: i1tprCHl.jpg]
[Image: ps2BpzNl.jpg]
-two dys 20a blheli_s and an esc with a 5v bec
-two superman 1404 3800kv and one f20 II 3250kv
-a pdb
-some wood, broken eclair frame...
-a jumper receiver tx801(?)
-ewrf vtx
-runcam swift with osd
-hq 4inch t-mount biblades (4030x2?)
-hq 3030x4
-green led strap in the back
i mention about build a 5inch whover, probably with an old noisy motorset; it goes a bit dangerous :-(
  • the.ronin
This is cool, i'm trying to almost the same thing after one of my baby hawk motors blew up.
So are you using a flight controller at all? Or just running the ESCs from the receiver? I guess SBUS won't work then.
I'm using a flight controller with tricopter setup, motors spin up, but cut out as soon as I give it some throttle.
[-] The following 1 user Likes joewickert's post:
  • hugnosed_bat
i use no flighcontroller, just a receiver, the motor for uplift is set to a poti, the rear motors are mixed,i only stear the two rear motors; throttle, left-right no other inputs.
it would need receiver with single channels to add signal wires. i use 3 esc each conected to a channel. this way wont work with an aio board, still looking for a reason to use an aio an get the help of a gyro.
does the tricopter settup probably work with the motor invthe back?
one thing to mention is: pitch forward does brake, pitch back gives more uplift: does it probably work if you pitch a bit backward?
