After being in the hobby for a while and breaking a lot of stuff I thought it would be good to have a motor tester I can use to help diagnose the health of a lot of spare motors I have. Also I've found in the micro category there is a lot of crap motors out there, or 3 of them are good and one is bad once I receive an order.
I hate killing 4in1 escs just to find this out..
So I put together an old f4 FC with a speedix blheli_S esc and I use a homemade XT60 passthrough adaptor to plug into my DMM for current readings. Real current readings and not the crap from an ESC current sensor. I rarely trust those things now.
I can:
![[Image: attachment.php?aid=4176]](https://intofpv.com/attachment.php?aid=4176)
![[Image: attachment.php?aid=4175]](https://intofpv.com/attachment.php?aid=4175)
Happy with this and it keeps the mind busy when one can't fly atm.
Does anyone else have a home made motor tester?
The only thing I need to keep mind of is to change the motor pole setting in bf configurator when using RPM telemetry otherwise you will get errors each time the pole count changes on a motor. Mostly the small micro class of motors need this.
cheers,
ph2t.
I can:
- test the motor is actually working
- test RPMs as I have RPM filter enabled with JM 15.73 firmware on it
- test current draw on 2,3,4,5 and 6S - both the esc and fc are 6S rated
cheers,
ph2t.
