19-Mar-2024, 03:17 AM (This post was last modified: 19-Mar-2024, 05:11 AM by JohnnyCornRocket.)
I'm working on my first build. I have this ELRS receiver and this VTX...but I'm unsure of the best place to put them.
The VTX doesn't fit into the 3d printed antenna hole, so I figured I would have it dangle out the back above the blue piece, and feed the 2 ELRS antennas through the hole instead.
But as far as where to actually place the components...
My initial thoughts were to put the ELRS on the bottom and the VTX on top. Pretty sure I'll need to be able to press the button on the VTX. But then it looks like I'll need to use that area for battery straps, and I don't think battery straps on a VTX seem like a good idea. My next thoughts were to put the ELRS on the bottom, and the VTX on top of that, but having them on top of each other also seems like a bad idea. Would it be feasible to put them both on the bottom, but with some kind of spacer like having the ELRS wrapped in kapton with adhesive foam tape and the VTX on top?
Thanks
Thanks
