19-Feb-2023, 01:39 AM (This post was last modified: 19-Feb-2023, 09:31 PM by Pathfinder075.)
Has anyone out there got an SPI ELRS board with a bricked ICM20689 gyro. I think Shellodan has one, thinking about it. there must be others too.
The boards that seem to be bugged are:
BetaFPV 5A AIO with SPI ELRS
BetaFPV 12A AIO with SPI ELRS
Crazybee 5A AIO with SPI ELRS
Crazybee 12A AIO with SPI ELRS
Basically the boards that use the BETAFPVF4SX1280 or CRAZYBEEF4SX1280 target on Betaflight, are the ones I know that can brick. There are potentially a bunch of other boards that use SX1280 that may be afflicted by it too, from DarwinFPV, T-Motor, HGLRC, GEPRC, Emax, iFlight and NeutronRC. So if you have some other board with an ICM20689 gyro that has no yaw on it, you could try as well.
Anyway, if you have one, could you install Quicksilver on it and see if it is still bricked.
So tonight while bored I thought why not flash the bricked 5A BetaFPV AIO that i got with the Meteor 65 I picked up cheap last year. So I started out by flashing latest version 0.9.5 but realised it wouldn't work with my ELRS 2 radio. So I then put on 0.8.4-dev (the last version that has a "BetaFPV Brushless ELRS" target). So when I got the screen with the quad image it was spinning on yaw when i turned it left or right. So that got me interested, so I partially reassembled it so i could fly it LoS. So it flew, flipped over, spins around in circles, which I think is motor direction related, but shockingly, while it was going nuts on the floor, yaw worked, ie, it spins left or right. Unfortunately I've run out of time for playing with it (past midnight), so will start again tomorrow and see if I can get it to hover. I think the problem is when i went to the motors tab and spun the motors the directions were all over the place, so i loaded up the ESC config and reversed the ones that were spinning incorrectly. This hasn't fixed it (maybe a glitch from using a dev version). They are still spinning at random, so i will have to do it from Bluejay directly.
So I need someone else to try this little experiment just to confirm it works for them too and isn't a fluke of some sort. If so, we may have the solution to the bricked gyro issue, ie, don't use Betaflight, use Quicksilver.
Try Not, Do or Do Not
- Yoda
- Yoda
