Threads: 13
Likes Received: 1 in 1 posts
Likes Given: 0
0 Sorry. Could not find a Li-Ion hardware Discussion.
Got a large Li-ion battery from iFlight for my Chimera 7. 22.2V/6S2P 8000 mAh FULLSENT LR.
This is my first Li-ion battery in a model. Use to large Lipo's
Need to answer the following in Betaflight Power & Battery.
Minimum Cell Voltage
Maximum Cell Voltage
Warning Cell Voltage
Any thoughts on some good values?
I know the web says Li-ion normal is 3.7 per cell and 2.4 to 3.0 min. Not sure I want my long range quad way out at or near minimums.
Thanks.
Mike.
Threads: 13
Likes Given: 0
0 Thanks for the great info. I'll plug it in and go fly.
Mike.
Threads: 59
Likes Received: 41 in 36 posts
Likes Given: 351
1 highly informative piece from iflight about the 21700 packets they use!?
Threads: 61
Likes Received: 1,027 in 741 posts
Likes Given: 97
53 If you know the brand and model of the cells, you can usually find a reliable discharge curve, manufacturer spec sheet, as well as reliable cycle life test data, and anything else you want to know about the cells. Unlike lipos, liions often have detailed specs and perform very close to the stated specs (for the big brands at least), not some imaginary marketing C number that you find on lipos.
If you know the amp draw of your setup, match it to the respective discharge curve, and that will let you know the realistic flight time to expect and also what the voltage reading under load would be at different levels of capacity remaining.
Threads: 1
Likes Received: 11 in 11 posts
Likes Given: 1
1 The Samsung 40T was a great cell that served me well for many years. but today you want a Molicel P45B wich outperforms the 40T by miles. make sure you have enough cooling if you stress your batteries. the max cell V can be left at 4.2V but you want to lower the min cell V down to 2.5V. i have my warning at 2.8V. the true power of a Li-Ion is between 3.8-2.8V above and below they drop quite quickly. Occasionally i fly mine down all the way to 2.5V but you have to be careful as below 2.8V they drop very quickly. if you want your batteries to live long then it's best if you stay between 4.15V-2.8V. If you need the extra punch you can go up to 4.25V and all the way down to 2.5V but that will shorten the lifespan. Molicel promises 500 cycles on their new cells.. i never had a battery with 500 cycles on it, so i abuse mine quite a bit expecting to reach 200 cycles which is totally ok for me.
don't forget to disable LVC on your ESC!!!
Threads: 61
Likes Given: 97
53 The screenshot is showing Blheli v14.0, which I believe was released 9 years back. I'm not sure any of the recent drone ESC firmwares still have this setting? But yes if you are using an older ESC, it would be wise to double-check.
Threads: 1
Likes Given: 1
1 25-Jan-2024, 09:34 PM (This post was last modified: 25-Jan-2024, 09:39 PM by StuweFPV.) yeah i know.. I'm sorry i just pickt the first pic on the internet and did not go in the shop, connected a plane and took a screenshot just to post it here... i currently use version 32.9.0.3 and the LVC shows on all my ESC's (Holybro, IFlight, Flycolor and APD) which are maybe 1 year old and some older. but they all have it. but hey if yours does not have it then just forget about it - no sweat. it was just to point out that if you fly Li-Ion and per default have LVC on at 3.6V, you're not benefiting from the new technology. I'd actually be worse than a lipo and you'd woder why..
