Hi all,
I recently helped a friend build a 17" quad that wont take off the ground.
When battery is plugged in we get the normal regular beeps and then when armed the motors start
and all is well however even under full thrust the motors accelerate but will not lift off the ground.
We first assumed that one battery did'nt supply enough current to the largish motors so we connected
2 in parralel but no difference.
I get the immpression that rotational speed of the motors are somehow lacking!
We then assumed that iNav might be the problem (we both are new to iNav) so we flashed the FC to
betaflight and tried the custom rates, aggressive and default.. no difference.
We now suspect that the motors are too small for the weight... don't know.
I will start with a list of the major components used:
Frame HSKRC LX800 17 inch. https://th.aliexpress.com/item/32994376918.html
Motors EMAX 12N14P. https://th.aliexpress.com/item/32484476504.html (they wont take 6s)
Propeller 17 inch Carbon Fiber.
ESC Aikon 55 Amp
FC Matek F722 HD.
Receiver and Camera DJI Air Unit.
Batteries x 2 paralled 4S 5000mAh.
Total all up weight 5.6 Kg (2 batteries included)
Probably will add GPS and LED's
The Motor Specification is as follows:
600 KV, Length 23.4 mm, Diameter, 41.5 mm, Cells Range 3 - 4S, Maximum thrust 1.78 Kg.
Maximum total motor thrust 7.12 Kg is this enough??
The frame will happily accomodate up to 19" props.
Can someone advise us what to do next,
If the motors are the problem...
What motors should he be looking at??
ESC Aikon 55 Amp
FC Matek F722 HD.
I HATE FRSKY!!!
