Yaw Oscillations in Hover
I just recently built my first quad, an Armattan f1-5 with SPracing F3 EVO FC with luxfloat, 20a littlebee esc, and Armattan 2204 2300kv motors.  I am learning the tuning process, and will probably figure this out eventually, but here is my issue:
I am getting huge yaw oscillations sometimes, traces look smooth at full stick input really noisy intermittenly during a hover.  From what I've been reading, it seems like everyone says to tune yaw last, but my yaw looks way more noisy than everything else on my quad.  I was hoping someone could point me in the right direction, I'm still new to all this so any tips are welcome Smile
I lowered yaw P quite a bit from the default luxfloat settings, where I was having the same issue, but not sure if this was the right move.
Another question about tuning: when adjusting values, how big of a step up or down do people generally use to do get PIDs in the ballpark?  Thinking I should use whole values for P, .01 increments for I, and 2 or 3 at a time for D, but I'm a noob so...
# Cleanflight/SPRACINGF3EVO 1.13.0 Jun  6 2016 / 00:03:29 (a77bc76)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature -TRANSPONDER
feature RX_SERIAL
feature SOFTSERIAL
feature FAILSAFE
feature ONESHOT125
feature BLACKBOX
# map
map TAER1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
set looptime = 1000
set emf_avoidance = OFF
set i2c_highspeed = ON
set gyro_sync = ON
set gyro_sync_denom = 1
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set serialrx_provider = SPEK2048
set sbus_inversion = ON
set spektrum_sat_bind = 0
set min_throttle = 1055
set max_throttle = 1940
set servo_center_pulse = 1500
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set retarded_arm = OFF
set disarm_kill_switch = ON
set max_arm_angle = 25
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set max_angle_inclination = 500
set gyro_lpf = 188HZ
set gyro_soft_lpf = 60
set moron_threshold = 32
set pid_at_min_throttle = ON
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq =  400.000
set failsafe_delay = 10
set failsafe_off_delay = 50
set failsafe_throttle = 1300
set failsafe_procedure = 0
set acc_hardware = 0
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set magzero_x = -39
set magzero_y = -126
set magzero_z = -139
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 0 1625 1925
aux 1 25 1 1100 1175
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 45 45 100 -1
servo 1 1000 2000 1500 45 45 100 -1
servo 2 1000 2000 1500 45 45 100 -1
servo 3 1000 2000 1500 45 45 100 -1
servo 4 1000 2000 1500 45 45 100 -1
servo 5 1000 2000 1500 45 45 100 -1
servo 6 1000 2000 1500 45 45 100 -1
servo 7 1000 2000 1500 45 45 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set 3d_deadband_throttle = 14852
set default_rate_profile = 0
set gimbal_mode = NORMAL
set acc_cut_hz = 15
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff =  5.000
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set mag_declination = 0
set pid_controller = LUX
set p_pitch = 33
set i_pitch = 30
set d_pitch = 23
set p_roll = 33
set i_roll = 30
set d_roll = 23
set p_yaw = 55
set i_yaw = 50
set d_yaw = 5
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 20
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set dterm_cut_hz = 0
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
# dump rates
# rateprofile
set rc_rate = 90
set rc_expo = 65
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
set tpa_breakpoint = 1500
After doing some thinking, It seems like this is only an issue when my motors are operating at an RPM right around 1330. I put my gopro on the quad, so that it would hover at a higher rpm, seems to have helped. It's not an issue in forward flight or climbing, so I'm thinking maybe its just frame resonance.
Frame resonance? Maybe, but I don't think I get frame resonance on any of my quads and you've got a high quality frame. Could be a mechanical issue: give the whole quad a check over.
Yeah, lowering P would be the first thing I'd try. You can go really low because it's just yaw. If that doesn't work, put I down really low. Why not try to banish it, because it should not be happening.
Sure, I think your incremental amounts for each gain are about right. You will probably see fairly obvious differences, which is good for learning about tuning. You'll narrow it down pretty quickly regardless.
Hi, I have the same problem as the OP on my new build.
qav-r 220 clone
cc3d f1 (it did the same on spracingf3)
emax lightning_s 35a esc
sunnysky 2204 2300kv motors
.zip   blackbox_log_2016-06-28_095042.zip (Size: 1.07 MB / Downloads: 545)
# BetaFlight/CC3D 2.9.0 Jun 25 2016 / 23:42:07 (3d9b180)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -ONESHOT125
feature -BLACKBOX
feature -AIRMODE
feature -SUPEREXPO_RATES
feature RX_PPM
feature MOTOR_STOP
feature FAILSAFE
feature BLACKBOX
feature SUPEREXPO_RATES
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
aux 0 0 2 1600 2100
aux 1 27 0 1300 1700
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set rssi_scale = 30
set rc_smooth_interval_ms = 0
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1040
set max_throttle = 1980
set anti_desync_power_step = 0
set unsynced_fast_pwm = OFF
set fast_pwm_protocol = MULTISHOT
set enable_buzzer_p6 = OFF
set motor_pwm_rate = 8000
set disarm_kill_switch = OFF
set telemetry_inversion = OFF
set vbat_hysteresis = 1
set align_board_yaw = 270
set gyro_lpf = OFF
set gyro_sync_denom = 2
set gyro_lowpass = 60
set deadband = 0
set airmode_activate_throttle = 1350
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = ON
set acc_hardware = NONE
set acc_lpf_hz =  10.000
set baro_hardware = NONE
set mag_hardware = NONE
set pid_process_denom = 3
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# profile
############################# PROFILE VALUES ####################################
set dterm_lowpass = 100
set dynamic_iterm = ON
set iterm_ignore_threshold = 180
set yaw_iterm_ignore_threshold = 35
set yaw_lowpass = 60
set pid_controller = INT
set p_pitch = 50
set i_pitch = 40
set d_pitch = 18
set p_roll = 45
set i_roll = 40
set d_roll = 18
set p_yaw = 80
set i_yaw = 40
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
# rateprofile
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 10
set thr_mid = 50
set thr_expo = 0
set roll_rate = 80
set pitch_rate = 80
set yaw_rate = 70
set tpa_rate = 20
set tpa_breakpoint = 1650
(28-Jun-2016, 02:34 PM)artur_k Wrote: Hi, I have the same problem as the OP on my new build.
qav-r 220 clone
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -ONESHOT125
feature -BLACKBOX
feature -AIRMODE
feature RX_PPM
feature MOTOR_STOP
feature FAILSAFE
feature BLACKBOX
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
aux 0 0 2 1600 2100
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set rssi_scale = 30
set gyro_lpf = OFF
set deadband = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# profile
set p_pitch = 50
set i_pitch = 40
set d_pitch = 18
set p_roll = 45
set i_roll = 40
set d_roll = 18
set p_yaw = 80
set i_yaw = 40
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
# rateprofile
set rc_rate = 100
set rc_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 80
set pitch_rate = 80
set yaw_rate = 70
set tpa_rate = 20
Just checked your Blackbox log...
your D gains for roll/pitch is a bit noisy, consider set dterm_lowpass = 60
Your Yaw is really really bad! mostly coming from P i would suggest set yaw_lowpass = 40
report back if you can Smile
(28-Jun-2016, 04:04 PM)Oscar Wrote: Just checked your Blackbox log...
No change, it only happens at a certain low throttle speed. It is fine above that all the way to full throttle and below as well.
.zip   blackbox_log_2016-06-28_165133.zip (Size: 776.23 KB / Downloads: 365)
If i put smaller props on it helps in a way that I have the hover point higher than the resonance. But it is still there. Is it my motors?
I changed escs as I had a similar yaw twitch on previous ones, changed the fc, softmounted the fc...
I had the same problem on my sparrow racing quad. I spent days trying to tune it out and was unable to. finally I was able to figure it out by overhauling the whole quad. turned out I was getting vibrations cause the screws holding my flight controller were a little lose.
Hey sorry for not updating this thread. The solution I found was to sandwich the fc between some small o-rings and the standoffs. There is some discussion elsewhere about the 6500 gyro picking up noise, which was my issue. Soft mounting the FC made all the difference.
(29-Jun-2016, 01:23 AM)DRohn Wrote: Hey sorry for not updating this thread. The solution I found was to sandwich the fc between some small o-rings and the standoffs. There is some discussion elsewhere about the 6500 gyro picking up noise, which was my issue. Soft mounting the FC made all the difference.
I tried that and it didn't help.
First I built this quad on a spracingf3 fc with 6500gyro and it was doing it, that's why I changed it for cc3d with 6000 gyro that doesn't suffer from noise, I have another quad - qav280 that is flying awesome on cc3d and is a really scruffy build.
I just read through 50pages of rcgroups betaflight thread and people, who seem to know what they are talking about, are suggesting going to much lower yaw P. Mine is at 80atm.
(29-Jun-2016, 02:19 AM)artur_k Wrote: I tried that and it didn't help.
I realized my problem was the gyro picking up noise when I tried running super low and super high PID values, the crazy oscillations were still there, so I figured my issue probably wasn't the PIDs.
Then I took the props off and went into the sensors tab of cleanflight, held the quad firmly on the bench and gave power with my TX, as I increased RPM, the yaw axis gyro started oscillating like crazy, causing the motors to start chattering, trying to compensate for what the gyro thought was movement on the yaw axis.  I was holding the quad to the bench, so I knew the gyro wasn't actually moving, so I determined the issue was noise.  People say that tuning is pointless until you can get your vibrations taken care of, and I would definitely agreee with that.  As soon as I put dampeners around my FC (not too tight, but not too loose either) the quad felt so much better, even with stock PIDs.
After getting all that sorted, I had some noise in my Dterm, so I set dterm_cut_hz = 20, I'm not sure why I went with 20, Still trying to fully understand what a low pass filter even is, but it seemed to take the noise out of my D trace and my logs are starting to look much better.
Some of the things I have been fiddling with and learning more about lately:
set looptime = 500
set gyro_sync = OFF
set gyro_lpf = 188Hz
Current PID's (using multiwii rewrite right now) are 2.3, .03, 23 for Pitch and Roll and 8, .045, 0 for yaw.  Still not 100% dialed in, but I'm getting closer.  Here is a screenshot zoomed to show a flip and a roll, and also the log from that flight.
https://drive.google.com/open?id=0B1Ant8...HhGb0tnVUE
(29-Jun-2016, 06:52 AM)DRohn Wrote: I realized my problem was the gyro picking up noise when I tried running super low and super high PID values, the crazy oscillations were still there, so I figured my issue probably wasn't the PIDs.
set looptime = 500
set gyro_sync = OFF
So much better! motor outputs are smooth as silk Smile
low pass filter is basically a filter that blocks high frequency signal or noise, and only allow the lower frequency signal to pass through.... the value you give it is the frequency threshold... so if it was 60, and now you set it to 20, you will filter out more noise and giving you cleaner signal..... however it comes with a delay penalty, the lower number you give it, the more delay you introduce to the filter...
I'm coming back with some good news. I properly soft mounted the fc using rubber orings from b&q and got rid of the oscillations! I just have sort out prop wash shake as other than that it's flying fine. I'm really enjoying the low throttle on blheli_s.
(04-Jul-2016, 05:21 PM)artur_k Wrote: I'm coming back with some good news. I properly soft mounted the fc using rubber orings from b&q and got rid of the oscillations! I just have sort out prop wash shake as other than that it's flying fine. I'm really enjoying the low throttle on blheli_s.
Awesome news artur, glad to hear it :Smile
Is there anything specific you can do about the prop wash? I notice some shake when I let my quad drop straight down and catch it with the throttle, but I thought that was pretty normal as the rotors are descending through the turbulent air that they created.
  random uncommanded yaw issue in flight? husafreak 30 971 16-Jan-2024, 05:32 AM
Last Post: husafreak
  Help Drone won’t hover Crazyart 14 1,544 24-Mar-2023, 01:21 AM
  Help Pitch axis oscillations and hot motors Extrm 0 313 08-Jul-2022, 07:54 PM
Last Post: Extrm
  Matek AIO FC yaw twitch issue TomP7715 5 1,204 22-Sep-2018, 10:51 PM
Last Post: Fisherking
  Help No pitch, roll or yaw commands working DannyZ 2 1,263 21-Jun-2018, 07:23 PM
Last Post: Drone0fPrey
