06-May-2017, 11:41 AM
Hi,
I really need some help. I'm at the final stage of building a Chameleon and I cant get the tx and rx setup. I bought a Taranis QX7 and an XSR rx - both packages are labelled "EU LBT" as i'm in the UK.
I have installed Open TX 2.2 on the Taranis and selected EU when flashing firmware. On my first attempt to bind I had the tx in bind mode (chirping) and held down the button on the XSR and applied USB to the FC (BFF3). I get 2 solid LEDs on the rx. I tried several times but no luck. I have D16 selected in the model setup.
I thought maybe the XSR firmware was wrong, so plugged in to the s-port on the QX7 and flashed with version 151118 from the FrSky website. I used the LBT firmware file, not the non EU one.
Again trying to bind and I get 2 solid LEDs no matter how long I hold the button. After removing power and re-applying I just get a single red flashing led on the rx.
I then did some searching on internet to see if this was a common problem which it seems it is, although normally down to incompatible firmware between tx and rx.
So, I flashed the QX7 internal module with the XJT-LBT build 151223 from FrSky site. Again I cannot get them to bind.
I would greatly appreciate some advice as I really want to get this bird in the air.
Many thanks
hendrixhughes
Many thanks
hendrixhughes
