XRotor 40A changed their circuit PCB
Hi There
I Have just received 4 XRotor 40A ESC (Asian Pacific) all the items passed "Anti-counterfeit Code" meaning that they are all genuine original.
I have also contacted hobbywing and they have confirmed the the new circuit is genuine .
When I was about to flush them with blheli I noticed that the PCB is different than the one seen in the blheli guide, on mine the MCU is F394 but it is turnd 90 degrees as well as the programming pinouts.
One other change is that the new ESC is using a new driver which is single IC is FD6288 where the old driver uses a 3 separate IC NCP5106B.
New Driver: FORTIOR FD6288 250v 3 phase HVIC.
Details:
Internal 200ns dead time.
link to the new driver:
http://www.fortiortech.com/en/produc...asp?id=133&i=3
I have open an issue in the BLHeli repository, so you can track as well
https://github.com/bitdump/BLHeli/issues/173
I have attached images of the new and old PCB.
If one of you guys/girls manage to install either blheli or blheli_s on this new PCB I would love to hear that.
Thanks
Tech Sgin
Attached Files Thumbnail(s)
  PWM circuit for a motor testing rig Pathfinder075 10 179 28-Mar-2024, 04:44 AM
Last Post: skywanderer
  Help 2 x Esc changed not working in Bf? Yelreppa 12 769 27-Nov-2022, 07:53 PM
Last Post: Yelreppa
  Help Hobbywing 40A - Resets Mid-Flight OscarWao 2 330 20-May-2021, 03:19 PM
Last Post: OscarWao
  Would the F80 Pro 1900kv blow my Holybro F3 32Bit 40A 4in1 ESC? silpheedx 1 464 09-Jul-2020, 02:31 AM
Last Post: voodoo614
  Solved iFlight SucceX 40A Mini ESC says 8bit instead of 32 staykindasick 3 4,489 01-Jul-2020, 07:15 PM
