Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 14-Feb-2017, 12:02 AM (This post was last modified: 22-Feb-2017, 06:04 PM by oyvinla.) I can't get the telemetry to work on my taranis, is there something I'm missing? I'm on Betaflight 3.1.5 - The smartport is connected to UART1 TX, same as on the picture (everything is connected like on the picture). - Telemetry is chosen in the configurator. - UART 1 is setup with both MSP for USB connection and smartport for telemetry (Will this work?). When I search for new sensors on the taranis, I only find the 4 values which the receiver is providing, nothing from the FC. • Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 It is Possible with the X-racer V3.1, it works on mine. Can you post a couple of screenshots of your configuration tabs in Betaflight? "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 Here they are and a CLI dump as well Code: CLI # dump # Betaflight / X_RACERSPI 3.1.1 Jan 31 2017 / 14:23:53 (b7c1c58) name - resource BEEPER 1 C15 resource MOTOR 1 A06 resource MOTOR 2 A07 resource MOTOR 3 A11 resource MOTOR 4 A12 resource MOTOR 5 B08 resource MOTOR 6 B09 resource MOTOR 7 A02 resource MOTOR 8 A03 resource MOTOR 9 A08 resource MOTOR 10 NONE resource MOTOR 11 NONE resource MOTOR 12 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A00 resource PWM 1 A00 resource PWM 2 A01 resource PWM 3 B11 resource PWM 4 B10 resource PWM 5 B00 resource PWM 6 B01 resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A08 mixer QUADX mmix reset servo 0 1000 2000 1500 90 90 100 -1 servo 1 1000 2000 1500 90 90 100 -1 servo 2 1000 2000 1500 90 90 100 -1 servo 3 1000 2000 1500 90 90 100 -1 servo 4 1000 2000 1500 90 90 100 -1 servo 5 1000 2000 1500 90 90 100 -1 servo 6 1000 2000 1500 90 90 100 -1 servo 7 1000 2000 1500 90 90 100 -1 smix reset feature -RX_PPM feature -VBAT feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -FAILSAFE feature -SONAR feature -TELEMETRY feature -CURRENT_METER feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -BLACKBOX feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -SDCARD feature -VTX feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature VBAT feature RX_SERIAL feature FAILSAFE feature TELEMETRY feature CURRENT_METER feature BLACKBOX feature AIRMODE beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB map TAER1234 serial 0 33 115200 57600 0 115200 serial 1 1 115200 57600 0 115200 serial 2 64 115200 57600 0 115200 led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 aux 0 0 0 1800 2100 aux 1 12 1 1700 2100 aux 2 25 1 1300 1700 aux 3 0 0 900 900 aux 4 0 0 900 900 aux 5 0 0 900 900 aux 6 0 0 900 900 aux 7 0 0 900 900 aux 8 0 0 900 900 aux 9 0 0 900 900 aux 10 0 0 900 900 aux 11 0 0 900 900 aux 12 0 0 900 900 aux 13 0 0 900 900 aux 14 0 0 900 900 aux 15 0 0 900 900 aux 16 0 0 900 900 aux 17 0 0 900 900 aux 18 0 0 900 900 aux 19 0 0 900 900 adjrange 0 0 3 2000 2050 18 4 adjrange 1 0 3 1850 1900 19 4 adjrange 2 0 3 1700 1750 20 4 adjrange 3 0 3 1625 1675 15 4 adjrange 4 0 3 1500 1550 16 4 adjrange 5 0 3 1350 1400 17 4 adjrange 6 0 3 1275 1325 9 4 adjrange 7 0 3 1125 1175 10 4 adjrange 8 0 3 900 1050 0 4 adjrange 9 0 0 900 900 0 0 adjrange 10 0 0 900 900 0 0 adjrange 11 0 0 900 900 0 0 adjrange 12 0 0 900 900 0 0 adjrange 13 0 0 900 900 0 0 adjrange 14 0 0 900 900 0 0 rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h set task_statistics = ON set mid_rc = 1500 set min_check = 1020 set max_check = 1900 set rssi_channel = 16 set rssi_scale = 30 set rc_interp = AUTO set rc_interp_ch = RP set rc_interp_int = 19 set rssi_ppm_invert = OFF set input_filtering_mode = OFF set fpv_mix_degrees = 0 set max_aux_channels = 12 set debug_mode = NOTCH set min_throttle = 1129 set max_throttle = 2000 set min_command = 1000 set digital_idle_percent = 4.500 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 400 set disarm_kill_switch = ON set gyro_cal_on_first_arm = OFF set auto_disarm_delay = 5 set small_angle = 25 set fixedwing_althold_dir = 1 set reboot_character = 82 set serial_update_rate_hz = 100 set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_wp_radius = 200 set nav_controls_heading = ON set nav_speed_min = 100 set nav_speed_max = 300 set nav_slew_rate = 30 set beeper_inversion = ON set beeper_od = OFF set serialrx_provider = SBUS set sbus_inversion = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autorst = 1 set tlm_switch = OFF set tlm_inversion = ON set sport_halfduplex = ON set frsky_default_lat = 0.000 set frsky_default_long = 0.000 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set frsky_vfas_cell_voltage = OFF set hott_alarm_sound_int = 5 set pid_in_telemetry = OFF set vbat_capacity = 0 set vbat_scale = 110 set vbat_max_cell_voltage = 43 set vbat_min_cell_voltage = 25 set vbat_warning_cell_voltage = 28 set vbat_hysteresis = 1 set current_scale = 236 set current_offset = 0 set mwii_current_output = OFF set current_meter_type = ADC set battery_meter_type = ADC set no_vbat_level = 55 set use_vbat_alerts = ON set vbat_usage_alerts = OFF set vbat_usage_percent = 10 set align_gyro = DEFAULT set align_acc = DEFAULT set align_mag = DEFAULT set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 180 set gyro_lpf = OFF set gyro_sync_denom = 1 set gyro_isr_update = OFF set gyro_use_32khz = OFF set gyro_lowpass_type = PT1 set gyro_lowpass = 90 set gyro_notch1_hz = 400 set gyro_notch1_cut = 300 set gyro_notch2_hz = 200 set gyro_notch2_cut = 100 set moron_threshold = 48 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set alt_hold_deadband = 40 set alt_hold_fast_change = ON set deadband = 5 set yaw_deadband = 5 set throttle_correct_value = 0 set throttle_correct_angle = 800 set yaw_control_direction = 1 set yaw_motor_direction = -1 set servo_center_pulse = 1500 set tri_unarmed_servo = ON set servo_lowpass_hz = 400 set servo_lowpass = OFF set servo_pwm_rate = 50 set gimbal_mode = NORMAL set airmode_start_throttle = 1350 set failsafe_delay = 10 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_kill_switch = OFF set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set rx_min_usec = 885 set rx_max_usec = 2115 set acc_hardware = NONE set acc_lpf_hz = 10 set accxy_deadband = 40 set accz_deadband = 40 set acc_unarmedcal = ON set acc_trim_pitch = 0 set acc_trim_roll = 0 set pid_process_denom = 2 set blackbox_rate_num = 1 set blackbox_rate_denom = 2 set blackbox_device = SPIFLASH set blackbox_on_motor_test = OFF set ledstrip_visual_beeper = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 profile 1 set gps_pos_p = 15 set gps_pos_i = 0 set gps_pos_d = 0 set gps_posr_p = 34 set gps_posr_i = 14 set gps_posr_d = 53 set gps_nav_p = 25 set gps_nav_i = 33 set gps_nav_d = 83 set yaw_p_limit = 500 set pidsum_limit = 0.500 set d_lowpass_type = BIQUAD set d_lowpass = 100 set d_notch_hz = 260 set d_notch_cutoff = 160 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_thresh = 300 set anti_gravity_gain = 3.000 set anti_gravity_rate_max = 80 set setpoint_relax_ratio = 30 set d_setpoint_weight = 189 set yaw_accel_limit = 10.000 set accel_limit = 0.000 set iterm_windup = 50 set yaw_lowpass = 0 set p_pitch = 47 set i_pitch = 50 set d_pitch = 24 set p_roll = 47 set i_roll = 40 set d_roll = 24 set p_yaw = 90 set i_yaw = 45 set d_yaw = 20 set p_alt = 50 set i_alt = 0 set d_alt = 0 set p_level = 50 set i_level = 50 set d_level = 100 set p_vel = 55 set i_vel = 55 set d_vel = 75 set level_sensitivity = 55 set level_limit = 55 rateprofile 0 rateprofile 0 set rc_rate = 160 set rc_rate_yaw = 100 set rc_expo = 12 set rc_yaw_expo = 5 set thr_mid = 50 set thr_expo = 0 set roll_srate = 72 set pitch_srate = 72 set yaw_srate = 77 set tpa_rate = 10 set tpa_breakpoint = 1650 #
• Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 14-Feb-2017, 04:41 PM (This post was last modified: 14-Feb-2017, 06:13 PM by sirdude.) I compared our set ups and there are some differences. First off I am not using Minim OSD, I am getting mine through the PDB. You are using UART 2 to drive the OSD and I am using UART 2 for soft serial which you have on UART 1. That shouldn't be a problem in and of it self. The only thing I really see is that you do not have softserial enabled in your configurator tab under "other features". That may or may not fix the issue. I have included screen shots of my configuration for your review. I hope this is of some help to you....will be interesting to see what it takes to get it going. EDIT: I just realized that I am showing softserial under the ports tab (because I enabled it under configuration), but I don't seem to be doing anything with it..... "Damn the torpedoes!!! Full speed ahead!!!" • Posts: 236 Threads: 2 Likes Received: 66 in 45 posts Likes Given: 27 Joined: Jan 2016 Reputation: 17 18-Feb-2017, 09:48 AM (This post was last modified: 18-Feb-2017, 09:49 AM by AndreyM.) You have feature TELEMETRY disabled? Don't use dump, use diff instead. • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 It should be enabled as far as I know, but I will check it one more time • Posts: 307 Threads: 18 Likes Received: 69 in 48 posts Likes Given: 33 Joined: Sep 2016 Reputation: 9 You also have to arm your quad (remove props) to discover the FC sensors, this because you share the telemetry with UART 1 and it's get it second function when the board is armed. Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 (20-Feb-2017, 10:21 PM)Ikkuh Wrote: You also have to arm your quad (remove props) to discover the FC sensors, this because you share the telemetry with UART 1 and it's get it second function when the board is armed. Haha, I just figured it out, and was to post here, when I saw your post . You hit the nail, Ikkuh. The telemetry on UART1 is only working when the quad is armed and thus I had to search for new sensors when it was armed. Thanks! Posts: 307 Threads: 18 Likes Received: 69 in 48 posts Likes Given: 33 Joined: Sep 2016 Reputation: 9 Good to know that you have solved it, happy flying. Posts: 9 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Sep 2016 Reputation: 0 I had 3.1.15 flashed on mine and I couldn't set the max aux channels greater than 8. Went to 3.1.13 and it was find. Had smart port on uart2 and telemetry on aux 16. • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 (19-Mar-2017, 02:08 PM)kanexpl Wrote: I had 3.1.15 flashed on mine and I couldn't set the max aux channels greater than 8. Went to 3.1.13 and it was find. Had smart port on uart2 and telemetry on aux 16. I think they fixed it with BF 3.1.16 |
