https://www.thingiverse.com/thing:884620
Really nice mount, though would recommend reducing the height of the lens protector by about half if you want to add a filter to the camera.
Xiaomi Yi mount for ZMR250 |
https://www.thingiverse.com/thing:884620 Really nice mount, though would recommend reducing the height of the lens protector by about half if you want to add a filter to the camera. 14-Jan-2016, 04:10 PM Can't you make some holes in it ... 30g is a lot. Like make a cut out on the side and the back with two cross bars. Should/Could save you at least 10g Sky is where the fun begins! Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz Building: FPV49v4 modified 14-Jan-2016, 04:56 PM Could do, but that would make it pretty delicate. Its not a particularly light design, but its certainly strong. If you were trying to go for a light design, there are better mounts available that just form a wedge. 15-Jan-2016, 09:40 PM emh.. did i show you mine solution? 18-Jan-2016, 07:11 PM 03-Feb-2016, 04:55 AM I customized a design made by Ulflindestrom, a member on thinginverse.com to fit my QAV 210, QAV 180, Tweaker 180's and ZMR 180's. Here is 1 link to my QAv 210 GOPro mount, http://www.thingiverse.com/thing:1170646 Just use the customizer to make your own to fit your frame. very easy to do. and because you can adjust the parameters to suit your frame (up to a point) it will easily fit a GoPro or Xiaomi Yi Camera. Huge thanks to Ulflindestrom for making this mount available to customize and use. |
Design Radiomaster TX16S Crossfire Antenna Mount | relentlesstech | 0 | 303 | 28-Jan-2023, 07:55 PM Last Post: relentlesstech | |
XL Frame mount | Albert Hoffman | 0 | 296 | 15-Jun-2021, 01:41 PM Last Post: Albert Hoffman | |
Design Antenna mount | Kevin2112 | 27 | 2,030 | 03-Mar-2021, 10:28 PM Last Post: bffigjam | |
Design Tyro99 camera mount | Maiden Flight | 2 | 656 | 02-May-2020, 04:10 PM Last Post: Maiden Flight | |
Design Universal 35 degree Mobius Actioncam FPV mount | Drone0fPrey | 10 | 1,079 | 09-Apr-2019, 03:12 PM Last Post: Drone0fPrey |
