Threads: 13
Likes Received: 2 in 2 posts
3 Hey everyone,
i need some help with choosing parts for an X6 / X8 flying videoplatform.
as far as i got i had the
Antigravity 4006 from RC Tiger in mind.
Top side with something like 16x4 and bottom side like 14x6.5
Has anyone every build an X6/X8 (coax config) and can give me some tips & tricks?
Is this enough for an X6 to lift my DSLR (about 1kg) for 20 minutes?
Just had racer-Quads and wings until now ^^
Cheers
Diego
Sky is where the fun begins!
Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz
Building: FPV49v4 modified
Threads: 13
3 Has nobody in here any clue about Coax platforms?
Threads: 3
Likes Received: 0 in 0 posts
0 Most of the time, the coax I have seen uses similar props top and bottom though. Whether it will carry your camera and have a flight time of 20mins...You're gonna need ecalc for that.
6S?
Threads: 13
3 (15-Jan-2016, 05:01 PM)evilmerlin Wrote: Most of the time, the coax I have seen uses similar props top and bottom though. Whether it will carry your camera and have a flight time of 20mins...You're gonna need ecalc for that.
6S?
I'm totally open about this build.
My biggest packs only have 3700mAh at 4S, so i guess i still need new LiPos.
I will definitley go two prop sizes (areo-engineer here) xD
But i am really overwhelmed by all the motors out there.
That's where you all come in ^^
Threads: 3
0 Spinning large props like that you're definitely looking at some low KV motors, say 400KV for a start? I know I tried 400KV on 15" props before and you should really do 6S, not sure if you can get enough RPMs with a 4S. Can't really go wrong with T-Motors though or you could try KDEDirect too. Those two companies have some of the most reliable motors out there.
Oh oh and before I forget, I have read that there are sync issues with these low KV motors with BLHeli and SimonK ESCs. I am not sure if this has been resolved yet. There are certain models of T-motor ESCs that are designed for low KV usage and the XRotor ESC series from Hobbywing as well.
