Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 0
0 I've got the x4r connected to the sbus connection on the xracer. I'm running betaflight. I've checked serial tx for uart 3, toggled rx_serial under receiver mode and checked sbus. I'm still not getting anything from the transimitter. please help
Threads: 672
Likes Given: 2,027
139 So you bind it correctly? Chosen the correct mode in taranis ?
Could you try another UART just for testing?
Threads: 0
Likes Given: 0
0 Did you correctly use the SBUS port on the receiver? That was my problem when I switched from the NAZE to the X-Racer
AirBirds.de | Quads: Lumenier QAV-R 6" - DQuad RefleX 5"
