X4R-SB doesn't bind with Taranis SBUS
I'm not able to bind it to my Taranis.
I bind them the same way as I would with a D4R-II. Go to config page (page 2) on the Taranis, scroll down and press "bind".
The Tarais is beeping away as it should, but when I follow the instructions to plug in power to the receiver while holding down the F/S button, and I am getting flashing green and red light.
Tried many times, same result and no luck... turning RX off and on it just flashes with red light.
Some suggests on the internet it might be firmware issue, but I don't think it is!
Problem solved!
On my Taranis, I changed my internal RF mode to D16 mode instead of the D8 mode which I had it on before with D4R-II, and now it's bound Smile
Good job!
If it ain't broke, DON'T FIX IT!
My YouTube FPV Channel
  FC SBUS Out Rotems 2 270 18-Oct-2023, 09:00 PM
Last Post: Rotems
  Hd-Zero sbus on soft serial? Rob Axel 1 267 08-Aug-2023, 12:11 PM
Last Post: Pennywise
  Solved Taranis X9 Lite models Krayon70 3 429 01-Aug-2021, 07:36 PM
Last Post: MrSolo
  Bind and Fly Tracer Sphere 2 732 22-Dec-2020, 03:30 PM
  ImpulseRC Apex Lipo Pad Doesn't Stick the.ronin 10 1,231 23-Jan-2020, 12:15 AM
Last Post: kingstar
