20-May-2017, 05:13 PM
my x4r-sb binds but will not do anything in the receiver tab in betaflight 3.1 - i usually set swithces after i do channel mapping n ensure signal from the taranis, not getting that with the x4r-sb. Running betaflight f3 flight controller. i have 2 x4r-sb and both are doing this so i dont think theyre broken. yes im familiar with building quads n i've never seen this before - i usually use xm+ receivers but gave these a try hoping for even longer range - the receivers bind fine - shows a solid green light after binding. serial rx set correctly to uart2 as i soldered to and smart port is connected and working being my taranis says "telemetry lost......telemetry recovered" yes, i've checked the signal wire at least 50 times. yes config is set to s.bus.
i know im missing a small piece in this puzzle - i usually use xm+ which are totally plug n play - i wire them n they work first try. just looking for someone familiar with this issue because i been researching it for 2 days now n i cant find any explanation, except people who have this problem, post it, get a solution but dont post that
