X220 wizard
Hey there, thanks for all the info!
My wizard x220 is having an issue. Once I arm it and give it a small amount of throttle, motors 1 3 and 4 spool up to full throttle, while motor 2 remains at idle.
When I give it full throttle, all motors spool up to full throttle and then motor 2 winds down to idle.
Can you point me in the right direction on fixing this issue?
Double check to make sure there are solid connections from the motors to esc's and to the rest of the quad. Could be a loose solder joint.
Is this happening with props on or on the bench?
If it is able to maintain stable hover, don't worry. Just test carefully Smile
  Eachine wizard x220 v2 setup shahinsa 4 580 17-Nov-2022, 09:17 AM
Last Post: shahinsa
  Motor issue on brand new Eachine Wizard X220 V2 shahinsa 8 644 16-Nov-2022, 01:01 PM
  Solved Wizard x220s ARF with X8R receiver (rx_failsafe) C_Sagan_42 4 296 31-Oct-2022, 01:43 PM
  Missing Model Wizard rgtoth 1 715 19-Jun-2022, 11:46 PM
  Help fixing an old drone (Wizard X220) Nuke 11 1,075 26-Dec-2021, 07:35 PM
