X-Racer v3 / Oneshot, multishot
Hi.
Betaflight 3.0.1 (X_RACERSPI) in now configured into my new X-Racer V3 FC.
I also have 4 DYS XM20A ESCs flashed with BLHeli Rev 14.7.
Oneshot125, 8Khz Gyro freq, 4Khz PID loop freq => Works well  (cycle time: 125, CPU load: 15%)
First problem:
Oneshot42 or Multishot => Motors won't turn at all.
2nd problem:
Oneshot125 and 8khz PID loop freq, throttle down => Motors turn erractically and slowly.
Accelerometer is off.
Airmode permanently enabled
Dump:
# dump
# BetaFlight/X_RACERSPI 3.0.1 Oct 18 2016 / 10:40:35 (48b7b4f)
# name
name -
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature RX_SERIAL
feature FAILSAFE
feature AIRMODE
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 1500 2100
aux 1 27 1 900 2100
aux 2 12 2 1500 2100
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1157 1842
rxrange 1 1155 1841
rxrange 2 1156 1844
rxrange 3 1152 1844
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interpolation = AUTO
set rc_interpolation_interval = 19
set rssi_ppm_invert = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1100
set max_throttle = 2000
set servo_center_pulse = 1500
set max_esc_throttle_jump = 0
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = OFF
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set gimbal_mode = NORMAL
set acc_hardware = NONE
set acc_lpf_hz =  10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set pid_process_denom = 2
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
# profile
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 500
set pidsum_limit = 700
set dterm_lowpass_type = BIQUAD
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set pid_at_min_throttle = ON
set iterm_throttle_gain = 0
set setpoint_relax_ratio = 30
set dterm_setpoint_weight = 200
set yaw_rate_accel_limit = 220
set rate_accel_limit = 0
set accum_threshold = 130
set yaw_accum_threshold = 32
set yaw_lowpass = 0
set pid_controller = BETAFLIGHT
set p_pitch = 58
set i_pitch = 50
set d_pitch = 22
set p_roll = 43
set i_roll = 40
set d_roll = 20
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity =  2.000
# rateprofile
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
Have you calibrated the escs after you changed between the pwm protocols? (Pwm/Oneshot/multishot)
Does the escs actually supports oneshot 42 or multishot with the default blheli fw? It could be that you needs to flash them with custom blheli firmware
I know now why I do have those problems.
If I look at my FPVModel order, my ESCs are supposed to be DYS XS 20A.
I've removed the tape from my ESCs and in reality I found out that I have DYS XM 20A which are only Oneshot 125 compatible.
They sent me the wrong ESCs !!!!
Oh well !
Yeah, that is probably the reason. Regarding your second problem, if you want to run pid looptime at 8k, you will have to set custom esc Pwm speed at lower than 4000 with Oneshot125. That is as fast as it is possible to run the Oneshot125 protocol
set use_unsynced_pwm = ON
set motor_pwm_rate = 2000
You could try 4000 as well, but you could get some desync problems. I had it with littlebees and 4k
(12-Dec-2016, 06:30 AM)oyvinla Wrote: set use_unsynced_pwm = ON
Will try that ... thanks !
You can set everything in the betaflight gui right under where you change the pwm rate, but I guess you already knew Smile
XM20A will support up to 32khz i believe. You just have to flash multishot blheli on it
  Help X racer F4 installation... Wesbird 11 2,434 08-Jun-2018, 06:50 PM
Last Post: Hypurr
  X-Racer F303 Board, LEDs in Cleanflight sher8256 22 10,141 07-Feb-2017, 08:26 AM
Last Post: alanwangwang
  X racer F303 V3.1 how to do 8K/8K? oyvinla 12 4,850 13-Dec-2016, 11:03 AM
Last Post: AndreyM
  Discussion X-Racer v3.1 + Betaflight v3.0.0 (self yaw) yaoweic 3 1,400 13-Oct-2016, 06:28 PM
Last Post: yaoweic
  [SOLVED] X-RACER f303 + XM30A motors don't start stevensav 5 5,457 07-Sep-2016, 10:00 PM
Last Post: sloscotty
