09-Mar-2016, 12:15 AM
(08-Mar-2016, 06:02 PM)CrashWorks Wrote: Just checking voltage on the Vbatt mod... OK for 3s and/or 4s input?It is the standard VBAT circuitry, used on all FC's. Good for 6S. (6x4.2/11 = 2.3V)
The LEDs are another issue. Am i correct in assuming that pin29(PA8) on the processor puts out data at 3.3v and the LED strip (WS2812) works on a data input of around 5v, kinda like sonar? In that case, a couple of diodes and a 10k resistor should couple data and both get the voltage they like while sharing the same 5v power supply...
Thanks for your help, I love to build... but this damn programming thing...
Im working on feasability study for the Xracer project, looking at mods, size and weight... I hope to come up with a "bulletproof" FC
Blue Skies, Brother
-kenny
As said, the classic way of connecting WS2812 to a 3.3V signal is to lower supply voltage with one diod in series. Can't see how two diodes and a resistor would be connected. A non-inverting transistor stage would be fine.
/A
