Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 0
0 Recently purchased wizard x220 latest version f3, 2205, blheli s esc etc. FS-16 tx and fs-IA6B receiver. Did not yaw out of the box long story short during process of using beta flight lost factory tx settings and cant bind to drone. It uses ppm but not familiar with setting up binding process to f3 board. Any help is welcomed.
Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 as you are using IA6b receiver, you should use the bind pins plug (signal + ground) on the last pins.
then powerup get fs-16 in bind mode.... done
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 672
Likes Given: 2,030
139 Moved to beginner section
