11-Aug-2017, 06:08 PM
I got serius throttle/ecs problem with my x220 makes this drone unable to fly. I made a video, ecs calibration don't work. I many YT videos that show how to set wizard and nothing work.
Wizard x220 problem. My video |
11-Aug-2017, 06:08 PM I got serius throttle/ecs problem with my x220 makes this drone unable to fly. I made a video, ecs calibration don't work. I many YT videos that show how to set wizard and nothing work. 12-Aug-2017, 06:53 AM The first thing that comes to my mind is that this is just Airmode spooling up the I-term. Have you tried flying it? make sure failsafe is working properly and try it outside with some props on. 12-Aug-2017, 07:57 AM I turned airmode etc. off in betafligth. Ok, as far as I can see, you have the throttle above min check which again will activate the pids which can cause I term windup when the quad is on the bench without props. I guess it doesn't happen if you just arm it and keep it at idle? Have you flown the quad? You say it is unable to fly, but is that just based of your findings in that video? 13-Aug-2017, 04:05 PM it's normal... all quads do that on the bench, because they don't have props on... try to put props on, find a empty place to test hover it. 15-Aug-2017, 02:49 PM Timing is everything. I just ordered my first quad last night, a wizard x220. I'm a rookie at setup and betaflight as well so standby for questions. |
Problem with opening bootloader | Adicjusz | 1 | 129 | 25-Mar-2024, 08:04 PM Last Post: SnowLeopardFPV | |
Video out from DJI Goggles v2 to android stuttering heavily | doraymon | 4 | 156 | 16-Mar-2024, 04:36 PM Last Post: doraymon | |
Digital Video Transmitter Pin | Eyes.fpv | 2 | 190 | 22-Jan-2024, 05:02 PM Last Post: Eyes.fpv | |
Solved Tango II and Radiomaster Ranger Nano problem | Seii-FPV | 5 | 1,587 | 10-Jan-2024, 04:31 AM Last Post: Chekagos | |
Nazgul5 V3 O3 HD Radiomaster RP3 Problem | deadpool81 | 12 | 488 | 18-Dec-2023, 04:21 PM Last Post: deadpool81 |
