Wizard won't fire up
Hey guys, finally got my wizard in the mail. I've soldered my Spektrum satellite to my FC board and bound it. In Betalflight I can see that the TX is sending signals to the quad, but once I disconnect from Betaflight I can't get the quad to do anything.  Also, my vtx is pretty warm. Is this normal?? Yes, I had the antenna screwed onto it before I plugged it in.
Did you set an arming procedure in the betaflight or on the rx? It might just be a matter of arming the quad.
(22-Jan-2017, 09:09 PM)Bollucks760 Wrote: Did you set an arming procedure in the betaflight or on the rx? It might just be a matter of arming the quad.
I set it up in betalflight, but the switch does nothing once it is unplugged for the computer
While you where setting up the arm switch in beta flight was the program registering when the switch was thrown? Also I am not really familiar with the rx but is the maybe another arm sequence set in the setting for it? I know sometimes they default to yaw down.
On my DX8, I always have to lower the bottom throttle endpoint to be able to arm (I usually just adjust it all the way down).
When you flip your arm switch, is your flight controller responding? (LED on board changing from red to blue?)
  Smoke, Fire, and Sparks when I plug in battery NickyWicker 7 1,720 06-Mar-2024, 09:39 AM
Last Post: home003
  Solved SPI V3 ELRS won't bind nicetomeetyou 5 375 23-Feb-2024, 05:22 PM
Last Post: nicetomeetyou
Music Nazgul won't take off. Helltothena4093 3 229 12-Apr-2023, 06:03 PM
Last Post: Helltothena4093
Music Nazgul won't take off. Helltothena4093 2 261 11-Apr-2023, 10:48 PM
  Quad just won't fly stable Helmut585 5 496 17-Feb-2023, 04:24 AM
Last Post: cali_quad
