01-Oct-2023, 10:54 AM
I have a iFligt TurboBee 120RS V1 that´s not been in the air for some time cause of burning motors.
I changed the motors, soldered a Happymodel EP2 ELRS RX to it and upgraded BF firmware yesterday, and so far everything is fine, TX bound to RX, everything works in BF config, radio is properly setup and motors spin when I use the sliders in BF config.
Now to the problem, when I try to arm it from the TX the motors beeps to confirm they are armed but dont spin up!
When I unplug the LiPo and plug the quad to computer everything looks like it should in BF, the settings is the CLI I saved before upgrading FW that have worked before.
When flashing FW i choose Dshot, no telemetry mode and deletes the GPS, though when flashed a box that says something about "no motor input" appears and when I go to the Motors tab in BF the selected motor protocol is "Disabled", I have then changed this to DShot300 saved and rebooted, then the motors works fine using the sliders in BF.
Does anyone know what I´m doing wrong or what the problem could be?
I have five other quads I built myself that´s flying fine and I can´t find any diffrences in the settings that should make this happen..
