Threads: 24
Likes Received: 6 in 6 posts
Likes Given: 0
0 Why do they say KISS ESC's don't need to be calibrated?
Is it bad to calibrate them? I'm having some issues and I think/hope calibration might fix it
Threads: 30
Likes Received: 9 in 9 posts
Likes Given: 1
1 From the manual : Since the KISS24A RE have very accurate resonators, a throttle calibration isn’t really needed.
The default setting is 1000µS Min signal, 1050µS Start signal and 2000µS full Throttle signal.
Threads: 39
Likes Received: 16 in 11 posts
Likes Given: 0
2 KISS esc's are calibrated from factory and under regular situations should never need to be calibrated. I have fixed the odd issue by re-calibrating them so it can't hurt to try it but it's unlikely the issue. Also, with the new Dshot calibration never has to be done ever again
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Flyduino says that for the 24a RE only though. Any other/older kiss escs i would calibrate as usual.
Threads: 0
Likes Received: 1 in 1 posts
Likes Given: 0
0 I noticed strange behaviour when I still had little bee esc's so I calibrated them through the KISS GUI. After installing new KISS 24A escs and upgrading to Dshot600 I had the same issues despite knowing that no calibration is required.
I calibrated the escs again and it felt normal again.
Strange behaviour means a shaky feel as if the motors weren't 100 percent in sync. Hard to describe...
