Why KISS ESC doesn't need calibration?
Why do they say KISS ESC's don't need to be calibrated?
Is it bad to calibrate them? I'm having some issues and I think/hope calibration might fix it
From the manual : Since the KISS24A RE have very accurate resonators, a throttle calibration isn’t really needed.
The default setting is 1000µS Min signal, 1050µS Start signal and 2000µS full Throttle signal.
KISS esc's are calibrated from factory and under regular situations should never need to be calibrated. I have fixed the odd issue by re-calibrating them so it can't hurt to try it but it's unlikely the issue. Also, with the new Dshot calibration never has to be done ever again
Flyduino says that for the 24a RE only though. Any other/older kiss escs i would calibrate as usual.
I noticed strange behaviour when I still had little bee esc's so I calibrated them through the KISS GUI. After installing new KISS 24A escs and upgrading to Dshot600 I had the same issues despite knowing that no calibration is required.
I calibrated the escs again and it felt normal again.
Strange behaviour means a shaky feel as if the motors weren't 100 percent in sync. Hard to describe...
[-] The following 1 user Likes UnicornHunter's post:
  • fftunes
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 237 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 111 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 138 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 212 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 140 10-Mar-2024, 02:09 AM
