30-Apr-2019, 03:34 PM
Hi, I wanted to ask this question for long time. So which likely to lose signal 1st?
Which likely lose signal first vtx or rx? |
30-Apr-2019, 03:34 PM Hi, I wanted to ask this question for long time. So which likely to lose signal 1st? If you are using 2.4ghz rx and 5.8ghz vtx, most likely vtx will lose signal first. 30-Apr-2019, 04:23 PM It depends on the power, and frequency. Given the same power, higher frequency usually gives up first. 30-Apr-2019, 05:35 PM ok thanks all.. that will clear it 30-Apr-2019, 06:47 PM This is a good question and an important consideration when planning a build and what components you are going to use, as you definitely want to lose video before receiver. It's bad enough losing your beloved quad in a flyaway, but it's worse having a first-hand view of it as it tries to make it's way back to China. Dude, where's my quad? |
Help Radio won't arm quad when VTX is plugged in | CAAMMMM | 9 | 373 | 24-Jun-2023, 04:40 PM Last Post: aerokam | |
Help [SOLVED] help on setting up Taranis to change vtx band and channel with LUA script | sim_tcr | 10 | 1,313 | 24-Apr-2023, 08:20 AM Last Post: sim_tcr | |
Oversky XR602T-A RSSI signal issue | finnigan | 6 | 897 | 25-Mar-2023, 12:15 AM Last Post: romangpro | |
VTX Administrator in Expresslrs 3.0 | pofotiou | 2 | 2,435 | 22-Feb-2023, 06:50 PM Last Post: pofotiou | |
Help PLEASE HELP to send PWM signal from TBS Crossfire on AUX4 | June | 2 | 1,416 | 20-Dec-2022, 03:13 PM Last Post: June |
