Threads: 16
Likes Given: 48
5 My current hardware provides me with two OSD options.
1) Runcam Swift 2 RR
2) PDB - Mateksys HUBOSD with STOSD8
I'm currently making use of the Runcam OSD (was just more convenient at the time) which shows me VBAT, but no current data etc. I've been toying with the idea of switching to the PDB OSD, but do not really know what benefit I would be getting by doing this? What are the reasons for wanting to see current draw?
If my post helped you...hit the RATE button.
Threads: 38
Likes Given: 1,881
72 Seeing instantaneous current draw isn't that interesting, but you can instead see how much battery power has been used in terms of mA/h. This is a much better metric than battery voltage to judge when it is time to land.
So, if you have a current sensor and you have calibrated it so that it is accurate, you will be able to see when you have used 80% of the battery's capacity which is when you should land.
Threads: 16
Likes Given: 48
5 (10-Jan-2018, 10:15 AM)unseen Wrote: Seeing instantaneous current draw isn't that interesting, but you can instead see how much battery power has been used in terms of mA/h. This is a much better metric than battery voltage to judge when it is time to land.
Thanks! mA/h monitoring makes sense. I see Oscar has an article on this and the calibration process. Might be worth switching.
Unrelated to the topic, but something I want to make sure of: Is looks like STOSD8 now also supports RSSI, which is something I am definitely interested in. This should be as simple as wiring up the RSSI pad on my X4RSB to the RSSI pad on my HUBOSD8-SE, right? As far as I can establish both are PWM.
Threads: 16
Likes Given: 48
5 I'm all for reliability. Having both my OSD and Taranis reporting and monitoring is a plus! Done, I'm switching. Thanks for the great feedback unseen.
