I noticed a new feature in Betaflight called "Anti-Gravity" just wondering what that does?
What is Anti-Gravity in Betaflight? |
01-Jun-2017, 11:08 AM In simple terms, I think it increases "I" when you punch the throttle so it punches straighter. When you set the gain greater than 1 and leave the other settings default, BF will multiply your I terms by gain when the throttle passes some high level for some amount of time like 350ms or whatever the value is. So when you do a full throttle punch out the I terms increase so the quad keeps it's position and doesn't dip or roll. 01-Jun-2017, 11:11 AM So with the right tune, you don't need anti gravity? When I do a full throttle punch, its never dipped or anything, and to be honest Mines far from perfect tune. Or am I missing something here? 01-Jun-2017, 11:13 AM This is true. But too much I causes the copter to feel stiff. Antigravity allows you to have lower I for your normal flight and it automatically multiplies I on punchouts. With antigravity the tuning procedure changes where you don't tune I for punchouts just use enough I to maintain position and not allow drift. 01-Jun-2017, 02:12 PM (This post was last modified: 01-Jun-2017, 02:15 PM by Drone0fPrey.) (01-Jun-2017, 11:13 AM)JPFlorida Wrote: This is true. But too much I causes the copter to feel stiff. Antigravity allows you to have lower I for your normal flight and it automatically multiplies I on punchouts. With antigravity the tuning procedure changes where you don't tune I for punchouts just use enough I to maintain position and not allow drift. This is how I understand it as well. Here is a video from Joshua Bardwell about it. |
Betaflight Github questions | Rob Axel | 6 | 196 | 13-Feb-2024, 11:40 AM Last Post: Rob Axel | |
betaflight config 10.10 RC2 issue | Rob Axel | 3 | 227 | 10-Feb-2024, 01:21 PM Last Post: Rob Axel | |
Betaflight Motor Test Results in SmokeStopper overvoltage | LoganFPV | 5 | 233 | 01-Aug-2023, 11:22 AM Last Post: hugnosed_bat | |
Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? | MindBenderFPV | 2 | 3,082 | 18-Jun-2022, 09:10 AM Last Post: SnowLeopardFPV | |
Solved Betaflight 4.3.0 RC3 | SoCal_FPV | 5 | 527 | 17-Feb-2022, 06:30 PM Last Post: SoCal_FPV |
