Weird Betaflight F3 OSD problem
The OSD on BFF3 is acting weird.  When I connect the battery, I either get the OSD and a black background or I get the camera feed without the OSD.  It just started doing this, it was fine before.  I likely damaged the FC when the VTX shorted. Given the problem, I have already ruled out the camera or the VTX.  VTX is new after the other one shorted.
It sounds like there is something wrong with the OSD or FC.. Vin isn't going through the OSD chip and coming out to Vout as it's supposed to..
could you check the soldering on Vin/Vout pads and make sure they are not shorted, or likely to be shorted? Re-do the soldering if possible. Also check the pins of the OSD chip make sure nothing is shorting the chip connections (the "legs")
That was the first thing I did. Resolder Vin and Vout. Also looked at the osd chip, but I will give it another close look.
Probably time for a new FC. I saw a target for CL racing F7. Might be my next FC.
Same behavior here, is there a known tshoot fro the OSD chip ?
Also i cannot seem to find any replacement chip (ab7456)
Here you go
https://www.aliexpress.com/w/wholesale-Max7456.html
Datasheet
https://www.maximintegrated.com/en/produ...X7456.html
I ended scrapping the board.
  Help Problem with GEP-F411-35A AIO + VTX V1 Walksnail Adam0880 2 282 09-Mar-2024, 08:35 PM
Last Post: Adam0880
  Help Problem accessing the ESP8285 chip on MATEK FC F405 WTE remi.auge 2 193 05-Mar-2024, 12:49 PM
Last Post: remi.auge
  Issue "Mixer Mode Problem detected" need help Steven FPV 9 287 24-Jan-2024, 06:36 AM
Last Post: Steven FPV
  Diatone stack current sensor problem Myman 10 1,526 27-Dec-2023, 12:02 AM
Last Post: Birbal
  Help Matek 411 Wing BAROMETER problem capediablo83 0 135 19-Dec-2023, 04:15 PM
Last Post: capediablo83
