VTX power connector ripped off
The power connector has come off my vtx aomway 200mw.
Does anybody know where I can solder the power wires as the solder pads have come off also. Thanks.
[Image: XYkWSail.jpg]
There's a but of metal still showing on that pad test with multimeter to pads on the top. If it ls the power. Then neg can do to Sam is I soldered mine to. They will be shared ground
Not sure you'll get continuity from that smidgen of pad, maybe scratch back the pcb from above the pads to se if theres some trace
solder the positive wire on the right side terminal of the SS14 diode (the black rectangular part on top of your ripped power connector). negative wire can be on the soldered leg of the sma connector.
(21-Feb-2016, 01:24 AM)CurryCat Wrote: solder the positive wire on the right side terminal of the SS14 diode (the black rectangular part on top of your ripped power connector). negative wire can be on the soldered leg of the sma connector.
Fixed it!
Thank you much appreciated Smile
[Image: ESLGdf1l.jpg]
  Analog VTX for PAVO20 GlebSh 3 227 20-Apr-2024, 03:41 PM
  Help Vtx overheating battfish 3 236 04-Apr-2024, 12:05 AM
  New Product AKK Alpha 10 5.8GHz 10W VTX SnowLeopardFPV 8 399 19-Mar-2024, 05:54 PM
Last Post: Suros
  Help Random VTX frequency on power up cst3x6 7 415 27-Feb-2024, 10:16 AM
Last Post: cst3x6
  Help MO1 AIO V2.1 VTX not sending signal ThatOneGuy_ 0 158 24-Jan-2024, 09:44 PM
Last Post: ThatOneGuy_
