Threads: 11
Likes Received: 21 in 11 posts
Likes Given: 1
3 So I have been reading a bunch of tips from people saying that its best to zip tye your vtx antenna to the frame so that when you crash its less likely to break your vtx. This looks pretty simple and straight forward, but my vtx has a 90 degree bend on the sma which I dont think can be removed. So i think its either get some sort of pig tail adapter or figure another means of mounting everything.
Does anyone have any tips for this? Does this manner of mounting the antenna actually help out in crashes?
I am just trying to make it so I dont crash and rip my vtx apart in the first crash i have.
Threads: 136
Likes Received: 1,790 in 1,052 posts
Likes Given: 3,302
50 I too would be interested in what else people have come up with for saving the vtx
Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 get a vtx with pigtail, in case of crash the energy will be on cable not on the board of the vtx...
and there is nothing you can't disassemble
if you have a vtx with sma/rpsma socket already you can buy extension pigtail... yes few g more but better for crashes.
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 70
Likes Received: 742 in 378 posts
Likes Given: 577
44 this all or you can remove the connector to solder your own pigtail or antenna directly. You can do it in a lot of ways, but this is the most safe for your components IMO. What I like to do is to wrap the TX in tape to avoid metal shavings stuck to components:
You can just cut one side (that with two legs) and desolder the other one. Just be careful not to rip the pads off.
Threads: 11
Likes Given: 1
3 Awesome thanks for the input. I think I'll be picking up a pig tail for now. Anyone have any recommendations on where to buy them? Amazon seems to have a bunch but they all seem to be pretty long.
Threads: 136
Likes Given: 3,302
50 04-Feb-2017, 04:08 AM (This post was last modified: 04-Feb-2017, 04:09 AM by Drone0fPrey.) Thanks for the tips! Now I get to skip the cost of learning this from first hand experience! The guys!
