Hi folks and thanks in advance. I've never tuned a quad before so I'm very interested in learning anything I can. I see that the graphs at the bottom look VERY noisy compared to what I see online so I assume it's not working well.
Vortex Pro 250, Stock setup, DAL T5046, 2204-2300kv, 4s, Mobius in 3d printed 30 deg. holder.
2000ft altitude, approx 80f
Video:
https://www.youtube.com/watch?v=eXjiIeC3...e=youtu.be
Log:
https://drive.google.com/open?id=0BzOM6x...25yNjd3V1k
Config:
What else can I need to give you guys?
Video:
Log:
Config:
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# BetaFlight/IRCFUSIONF3 2.3.5 Feb 2 2016 / 22:58:50 (e973bb1)
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature GPS
feature FAILSAFE
feature ONESHOT125
feature BLACKBOX
# map
map AETR1234
serial 1 2 115200 38400 0 115200
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set emf_avoidance = OFF
set min_check = 1100
set max_check = 1900
set rssi_channel = 8
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set min_throttle = 1100
set max_throttle = 1900
set min_command = 1015
set servo_center_pulse = 1500
set enable_fast_pwm = OFF
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set serialrx_provider = SBUS
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 40
set vbat_min_cell_voltage = 30
set vbat_warning_cell_voltage = 30
set current_meter_scale = 0
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 90
set gyro_lpf = OFF
set moron_threshold = 32
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set failsafe_delay = 10
set failsafe_off_delay = 0
set failsafe_throttle = 1100
set acc_hardware = 0
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set beeper_off_flags = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 2 1300 1700
aux 1 1 0 1300 1700
aux 2 2 0 900 1300
aux 3 27 0 1700 2100
aux 4 25 1 1300 2100
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 991 2015
rxrange 1 991 2015
rxrange 2 991 2016
rxrange 3 991 2014
# servo
set gps_pos_p = 0
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 0
set gps_posr_i = 0
set gps_posr_d = 0
set gps_nav_p = 0
set gps_nav_i = 0
set gps_nav_d = 0
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 6
set yaw_deadband = 6
set default_rate_profile = 0
set gimbal_mode = NORMAL
set acc_lpf_hz = 20
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff = 5.000
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set delta_from_gyro = ON
set p_pitch = 100
set i_pitch = 35
set d_pitch = 81
set p_roll = 45
set i_roll = 23
set d_roll = 57
set p_yaw = 109
set i_yaw = 70
set d_yaw = 38
set p_pitchf = 1.500
set i_pitchf = 0.400
set d_pitchf = 0.010
set p_rollf = 1.100
set i_rollf = 0.400
set d_rollf = 0.010
set p_yawf = 4.000
set i_yawf = 0.400
set d_yawf = 0.000
set level_horizon = 6.000
set level_angle = 6.000
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 20
set i_level = 100
set d_level = 150
set p_vel = 120
set i_vel = 45
set d_vel = 2
set soft_gyro_lpf_hz = 60
set dterm_lpf_hz = 0
set acro_plus_factor = 0
# dump rates
# rateprofile
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 50
set thr_mid = 0
set thr_expo = 0
set roll_rate = 73
set pitch_rate = 73
set yaw_rate = 100
set tpa_rate = 33
set tpa_breakpoint = 0
# dump
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature GPS
feature FAILSAFE
feature ONESHOT125
feature BLACKBOX
# map
map AETR1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set rssi_scale = 30
set gyro_lpf = OFF
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 2 1300 1700
aux 1 1 0 1300 1700
aux 2 2 0 900 1300
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# rxrange
rxrange 0 991 2015
rxrange 1 991 2015
rxrange 2 991 2016
rxrange 3 991 2014
# servo
set gps_pos_p = 0
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 0
set gps_posr_i = 0
set gps_posr_d = 0
set gps_nav_p = 0
set gps_nav_i = 0
set gps_nav_d = 0
set gtune_pwr = 0
set deadband = 6
set acc_lpf_hz = 20
set p_pitch = 100
set i_pitch = 35
set d_pitch = 81
set p_roll = 45
set i_roll = 23
set d_roll = 57
set p_yaw = 109
set i_yaw = 70
set d_yaw = 38
set p_rollf = 1.100
set i_rollf = 0.400
set d_rollf = 0.010
set p_yawf = 4.000
set i_yawf = 0.400
set d_yawf = 0.000
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 20
set i_level = 100
set d_level = 150
set p_vel = 120
set i_vel = 45
set d_vel = 2
# dump rates
# rateprofile
set rc_rate = 100
set rc_expo = 70
set thr_mid = 0
set thr_expo = 0
set roll_rate = 73
set pitch_rate = 73
set yaw_rate = 100
set tpa_rate = 33
