Not sure what is going on here, tried two different receivers and two different vtx with same results. I'm pretty sure it is a power filtering or power supply issue, but I thought the DTFC's 5v regulator should be able to power everything. I'm getting 4.7v with just the rx on, and 4.6v with rx, vtx, and camera supplied from the 5v. Seems quite a bit lower than 5v, is it too low for my vtx or my camera?
apparently too dense to embed a video so here's the link:
https://www.youtube.com/watch?v=HGJ8sKRC...e=youtu.be
FC: DTFC w integrated pdb
RX: Frsky XSR
VTX: TBS Unify Pro@200mW
Camera: Foxeer HS1177
ESC: Aikon SEFM 30a
Motor: Tornado t-1
Things I will do next:
Edit: just found a 1000uF 25v cap, should I put it where the 5v and ground goes to the vtx and camera, or on the vbat pins, or where the battery leads come into the board (before the built in current sensor)?
If that doesn't work, I will try and supply the camera from the vbat tab. Is this a good idea, camera says 5-22v, but I know most people power the camera from 5v reg.
RX: Frsky XSR
ESC: Aikon SEFM 30a
Motor: Tornado t-1
