22-Jul-2017, 09:27 PM (This post was last modified: 23-Jul-2017, 12:35 AM by checcles.)
Everything works fine and dandy until I release a full throttle punchout and the quad tends to dip forward and wants to roll right. This is a new build and I'm stumped. See the video for an example of what I mean at 0:17, 0:29, and 0:34. The first part of the video shows that pitch and roll are fine until full throttle is released.
Parts: Martian II frame EMAX 2205 S motors DAL props Flycolor Raptor S AIO FC/ESC's Betaflight 3.1.7 Blheli_S 16.6 DSHOT 600 Acro mode only (accelerometer is off) Mid-quad is the center of balance TPA set to 0.10 I've double checked all soldering and connections
22-Jul-2017, 11:30 PM (This post was last modified: 22-Jul-2017, 11:32 PM by fftunes.)
Aside from adjusting PID (increase P and/or I) - did you try "antigravity" mode? It boosts i-term on quick throttle changes and should help in exact that situation.
There are 2 values to adjust in CLI to make it work right (don't know the names right now, you should find them by typing "get anti" i think). One is the factor for iterm boost, default is 1.0 i think, most people i read set it to something between 3.0 and 4.5. Other value defines how much of a throttle increase/decrease is needed to activate the effect. Default is 0.35 which means 35% of throttle range (in a very short time - if you're too slow you might reduce this value).
(22-Jul-2017, 11:30 PM)fftunes Wrote: Aside from adjusting PID (increase P and/or I) - did you try "antigravity" mode? It boosts i-term on quick throttle changes and should help in exact that situation.
I've got it set to 3.0 and 35%. Attached are my PIDs. I would assume that they are increased enough. They are perfect for everything but releasing the throttle punches.
So the quad dips to front right if I understand it correctly at punch outs? It could be hardware related though.. Let's troubleshoot!
First:
1. check if all your RX channels are centered at 1500 at idle 2. spin the motors with your hand, and see if your motors bearing sound normal, the same to other motors. 3. make sure all the screws are tightened properly: frame, arms, motor screws, FC screws...
If everything is fine at this stage and you are still getting the same issue... then you can move on to check the ESC and motors... It could be your front right ESC or motor...
Swap the front right ESC with the rear left one... test fly again see if it dips rear left this time... if yes then it's the ESC... if it still dips front right... then you can swap the motor as well this time...
If it still dips front right.. then we can probably rule out the motors and ESC's... and it's probably FC or Betaflight related...
