Very unhappy with my SunnySky 0705
So after a week and only 2 FPV flights I have decided that these motors are  Poop   Angry
After 3 test flights in the lounge 1 does't turn at all anymore. Yesterday 1 refused to run as fast as the others and causes death roll (if it even manages to take off) or uncontrollable yaw while trying to feed power to get it in the air. Now another is starting to mess around, only turning when IT feels like it! Seems to be developing the same metallic click I found with the 1st one.
So out of the 4 I have, only 1 is actually running properly, for how long though, who knows?
They have more vibration than the racerstar which I can't understand because the bell of the racerstar's seem to be loose, where the sunnysky's are tight and have no movement. The sunnysky's rattle like hell when running and actually get hotter than the Racerstar.
The Bat has actually spent more time disassembled since I put the new motors on, and has given me about 15 mins of flight. I now have 8 (out of 11) fully charged batteries that I now need to plug in and run in the motor tab of BF to discharge.
my new name today is Tom BD Bad MOOD!
Sad
That's bad news Tom.
That sucks! Bet these naked bottoms would have performed brilliantly if they had "pink skirts".  Tongue
If my post helped you...hit the RATE button.
[-] The following 1 user Likes xcalibur's post:
  • Tom BD Bad
I cant remember where but I watched a video but those motors made a terrible screeching noise from new, I was hoping they'd be a great improvement from the racerstar 0703 but I guess not Sad
Yeah the 1st one that died did make a horrible screeching noise at (13% throttle) stock idle, it did go away as soon as there was enough thrust to lift the quad. Personally, unless there is info from SunnySky about some improvements I would rather try the 0706 happymodel's. The 0603 that have been listed on BG recently I'm pretty sure will lack the torque needed for larger (55-65mm) props.
interesting, I kept pushing that sunnysky on my thrust test stand on 1-2s and had absolutely no issues with vibration, I didn't fly with it though... (BTW I actually forgot to post the thrust test results, lol)
Personally I wouldn't go with the happymodel either - the one I got had a lot of vertical movement, it seriously looks like it is missing a washer... it vibrated horribly on smaller (31-40mm) props, sounded perfectly good on bigger, 56mm prop though...
  • Tom BD Bad
Konrad, this is the 1st I have heard of anyone trying the happymodel, or even an actual thrust test of the sunnysky 0705.
I would love to see your results, did you test with the longer 65 parrot or 66mm eachine props as well?
Will post soon, let me do a bit of number crunching Smile
Done:
Happymodel
Sunnysky
[-] The following 2 users Like KonradS's post:
  • unseen, Tom BD Bad
Brilliant thanks Konrad! So despite the vibrations from the happymodel (which don't seem to be a problem with the longer props) they produce almost 5g more thrust than the SunnySky with 56mm props, at slightly less amperage draw. I think the Happymodel's might be half a gram heavier than the Sunnysky's, but with the extra 1mm rotor height and what look to be wider magnets (considering how closely spaced they are) they do seem to be a better choice, to me anyway.
Konrad, I haven't found conclusive info about whether the happymodels have bearings, also can you confirm the length of the wires on the happymodels, I seem to remember that they looked a bit short? Thanks buddy!
Happymodel is 0.7g heavier at 3.75g, sunnysky is 3.03g.
Happymodel has 5cm of wiring, sunnysky about 9cm.
Will check the bearings in the evening (about 10h), will let you know and update both threads.
  • Tom BD Bad
That 10h took a bit longer than expected Wink
Happymodel uses brass bushings:
[Image: GyMSowbl.jpg]
[Image: yvEmOU8l.jpg]
  • unseen
We're the bushings dry? You might be able to soak them in oil if it's that type of bronze.
  Help Diatone (sunnysky) 1408 4000kv motor issues Drone0fPrey 32 5,022 02-Sep-2018, 08:58 PM
Last Post: Tom BD Bad
