Threads: 7
Likes Received: 0 in 0 posts
0 I'm just putting my fpv and osd system on my 250 quad. The pdb is the demoncore and i was wonder if i can solder the vbat monitor leads that will go to the minimosd on the esc pads, or do the have to go on the battery pads?
Threads: 672
Likes Given: 2,027
139 27-Apr-2016, 01:35 PM (This post was last modified: 27-Apr-2016, 01:36 PM by Oscar.) It doesn't matter, the ESC pads is basically directly connected to the battery pads. so it's okay to use either one.
Threads: 7
0 Ok thanks oscar. That will make it easier as everying else is soldered in with little room to spare for the iron to get in there and hit the battery pads.
Threads: 76
Likes Received: 191 in 85 posts
Likes Given: 39
16 This might be irrelevant now, but you can get the osd to read vbat from the fc. It's just a setting you can enable.
Threads: 7
0 I have connected to the fc from the pdb esc pads now because I didn't trust the minim readings. But isn't the fc powered by 5v from the esc?
