Threads: 38
Likes Given: 430
118 1000 TVL will mean that the camera sensor will acquire more data and scale it down to NTC or PAL specifications.
If we compare images from a 600 TVL camera vs a 1000 or 1200 or 1500 TVL even via analog video feed we can seen the difference.
Threads: 172
Likes Given: 4,732
100 28-Jan-2023, 02:21 PM (This post was last modified: 28-Jan-2023, 02:26 PM by hugnosed_bat.) whats written on the paper doesnt need to match the truth ;-)
over analog video transmition, its limited to about 600tvl. a 1200tvl cam does still only show about 600tvl.
for analog fpv, tvl doesnt truly tell anything, i dont know a cam with less than 600tvl.
the tansmission is the bottleneck, you would get the full resolution with other connections than analog w
video transmission.
you wont get the relsolution rated on the goggle or cam by an analog vtx. its an old myth, its like teleshopping how the cam manufacturers provide a low resolution imagge and a high resolution image next to it, describe the tvl as the difference and its just far away from use over analog video transmission.
a higher resolutio on a cam can make a difference for dvr revording as example.
@kafie
it seems to be the tvl which makes the better image, but i believe other abilities of the image sensor does let higher tvl rated cams provide a better image.
edit:
the av in of your skyzone is limited to 576i?
Threads: 38
Likes Given: 430
118 Its not a resolution cap by Skyzone but a limitation of the AV signal (protocol) due to its limited bandwidth.
The great thing with analog AV is that its simple but has its limitations.
Did you consider a security night vision camera that directly outputs HDMI what you can plug straight into the HDMI in port of the goggles? I know the camera will be more expensive compared to an analog FPV cam but will give you a fairly high resolution.
Threads: 6
Likes Received: 73 in 48 posts
Likes Given: 41
1 30-Jan-2023, 03:45 AM (This post was last modified: 30-Jan-2023, 03:49 AM by cali_quad.) If the A/V port is analog, it will support two formats:
NTSC - 480i
PAL - 576i
This is interlaced video running at 59.94 fields per second (29.97 frames per second). For PAL it will run at 50 interlaced fields per second (25 frames per second).
Digital will serve you much better.
Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 2
0 Thank you everyone for the quick replies.
Based on what @hugnosed_bat, kafie1980 said, and on my own research there is no benefit to spending extra on the HD goggles.
This answers my question, thank you guys for the clarification.
