upgrading FPV camera
I am thinking to get a better fpv camera. I like racing and freestyle acrobatic flying.
I'm deciding on either the FatSharks Pilot HD, the HS1177M, or any other cameras you might suggest?
Which cameras do you guys prefer and why?
Runcam PZ0420M is probably the best all around camera I'd say. A little larger than HS1177 but has great settings out of the box, has nice thick connector cables that are not prone to breaking
I use the hs1177, 2.8 lens, IR blocked. Great camera for tight builds. you can order it with the plug on top or bottom.
Components split to 2 boards, connected by a ribbon cable
If you're careful, you can unscrew the back board, and put the lens thread directly on the front board (as a normal size board cam is set up) and flip the back board either horizontal, or in a trianle, and hot glue at desired angle
second PZ0420M Smile it's one of the best cam i used
Also the runcam sky is pretty good too and small form factor.
I use both.
A PZ0420 IR blocked and swapped it out for an HS1177 (needed a smaller one for the frame).
I really like both. Had some problems with the settings on my PZ0420 but got it dailed in.
Sky is where the fun begins!
Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz
Building: FPV49v4 modified
Runcam PZ0420M all the way
I have quad with the HS1177 and another with the Runcam PZ0420M. Runcam takes the win in picture quality.
TBS Zerozero is another option
I use both the HS1177 and the Runcam Skyplus (which is a PZ0420 in a alloy case). Both excellent FPV cams.
  New Product SpeedyBee 5.8GHz FPV Goggles Receiver Module (Analog) SnowLeopardFPV 2 1,280 14-Feb-2024, 03:24 PM
  Camera Plug Wiring segler999 5 362 30-Dec-2023, 05:17 PM
Last Post: segler999
  Camera and VTX connection best practice? husafreak 9 655 24-Dec-2023, 10:11 PM
Last Post: husafreak
  Help FPV goggles antenna boooood 2 705 04-Dec-2023, 05:38 AM
Last Post: Rob3ddd
  Best hd camera for 5 inch freestyle drone? PJKMBAKER 3 593 30-Sep-2023, 12:05 PM
