upgrading BL20A firmware - oneshot won't work
I flashed latest blheli firmware on my BL20A, with default settings, but now they won't work as soon as I enable OneShot - they just go into calibration mode by the sound of it as soon as OneShot is enabled in latest CF (also tried BF).
Does anyone know if there is something special that should be done to enable this?
I followed this instructions to flash my ESC's: http://blog.oscarliang.net/change-bootloader-esc-atmel/
I put blheli bootloader on my sn20's last month and all worked fine. Did you change the bootloader on yours?
(19-May-2016, 05:26 PM)Multirotor Army Wrote: I put blheli bootloader on my sn20's last month and all worked fine. Did you change the bootloader on yours?
I changed my bootloader to blheli just like the guide described. Running stock blheli settings and without oneshot everything is running as it should. As soon as I turn on oneshot it sounds like the esc goes into calibration mode
Downgraded to blheli 14.3 - everything works now
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 246 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  BLHeli32 recommended firmware Maverick 4 184 10-Mar-2024, 08:22 PM
Last Post: Maverick
  Help ESC Firmware Corruption import1107 0 182 30-Jan-2024, 08:13 PM
Last Post: import1107
  motors won't arm Huskydriver 1 180 03-Oct-2023, 09:44 PM
Last Post: V-22
  Help Why won´t it arm? swequad 2 187 01-Oct-2023, 06:53 PM
Last Post: swequad
