Unable to connect to ESC in BLheli
Using LittleBee 20A OPTO Pro ESC
[Image: uEgQN8k.jpg]
ESC wired to the PDB
[Image: OGVtA0U.jpg]
Signal and ground wire from ESC to FC
[Image: h416Vel.jpg]
When connected the battery, there's 3 beep/tone instead of 5. When connected to BLheli suite, when I clicked check, all ESC are blank.
[Image: Uz7eNUI.jpg]
I tried to click Read Setup, it will prompt me "Connection to ESC#1 Failed!"
[Image: EGXwqXG.jpg]
Solved!
Turns out that I soldered the ESC signal wires to 5V.
I think I recall that only 3 beeps is an error sequence for incorrect endpoint settings. But I could be wrong.....Have you calibrated them?
Have you tried BLHeli configurator (Chrome app) instead of BLHeli Suite?
Sounds like the ESC is not reacting to the commands from the FC. What ESC pwm protocol are you using? Try oneshot or multishot
(17-Jul-2017, 06:52 PM)RENOV8R Wrote: I think I recall that only 3 beeps is an error sequence for incorrect endpoint settings.  But I could be wrong.....Have you calibrated them?
How do I calibrate the ESC?
(17-Jul-2017, 07:42 PM)oyvinla Wrote: Sounds like the ESC is not reacting to the commands from the FC. What ESC pwm protocol are you using? Try oneshot or multishot
Absolutely no idea, just done with all the wiring and trying to follow video guides on youtube but stuck at the "check" stage.
The error you have reading is when you do not connect your battery when you are trying to read your ESCs.
(17-Jul-2017, 07:24 PM)sloscotty Wrote: Have you tried BLHeli configurator (Chrome app) instead of BLHeli Suite?
[Image: f0ofxQT.jpg]
Nothing happen when I click read setup
(18-Jul-2017, 04:56 AM)voodoo614 Wrote: The error you have reading is when you do not connect your battery when you are trying to read your ESCs.
So you are saying I should or should not plug in battery when reading the ESC?
You have to power the esc with battery. USB is not enough.
(18-Jul-2017, 08:56 AM)voodoo614 Wrote: You have to power the esc with battery. USB is not enough.
What I did is plug in USB, connect to BLheli Suite, plug in battery, hear 3 tone, click "Check", blank result.
Just in case it's possible, you can't have Betaflight "connected" at the same time.
(18-Jul-2017, 11:49 AM)sloscotty Wrote: Just in case it's possible, you can't have Betaflight "connected" at the same time.
Yup, understand this point. Was able to connect to BLheli Suite but just can't detect the ESC.
(18-Jul-2017, 09:46 AM)godzilla Wrote: What I did is plug in USB, connect to BLheli Suite, plug in battery, hear 3 tone, click "Check", blank result.
Did you select the correct Com port?
There were issues with passthrough on "some" (not all) FCs with Betaflight 3.1.6 and 3.1.7. For F1 boards installing 2.9.1 worked for flashing/configuring. For F3 boards some reported rolling back to 3.1.5. You might give that a try (depending on your FC). You can always go back and upgrade after you are done flashing/configuring your ESCs.
One source: https://github.com/betaflight/betaflight/issues/2544
(18-Jul-2017, 03:32 PM)voodoo614 Wrote: Did you select the correct Com port?
Pretty sure I did, else it won't connect to the software.
#15
(19-Jul-2017, 05:01 AM)godzilla Wrote: Pretty sure I did, else it won't connect to the software.
Technically, you have not connected. If you did, the screen would turn pink.
  Can I connect my DJI fpv v2 goggles to and dji fpv remote controller 2 to other drons qt179 4 141 08-Apr-2024, 10:57 AM
Last Post: roleyrev
Question Is it possible to test if an ESC works without soldering? HypnoToad 2 119 23-Mar-2024, 07:22 PM
Last Post: HypnoToad
  Blheli & Bluejay Eyes.fpv 5 154 09-Mar-2024, 12:02 AM
Last Post: Eyes.fpv
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 326 02-Mar-2024, 12:35 PM
Last Post: Luk5569
Exclamation SpeedyBee F7 ESC Question... Coleon 6 390 30-Jan-2024, 07:05 AM
Last Post: Coleon
