Tx not connecting to fc
Hey dudes. You guys have been great. Figured out a lot through reading the site and you tube. But another newbie question. My spectrum radio is bound to the serial telemetry receiver all motors running the correct way(awesome tutorial by the way) but in clean flight the radio is not working. Nor out of clean flight. I know it it is something small. Plz help. So close. This would be a great Xmas present! Lol
How do you want to connect it, pwm, ppm or serial. Witch RX and FC are you using?
To see the movement in the Receiver tab in Cleanflight, turn on the transmitter first, then plug in the USB cable and connect to Cleanflight.
(The other issue is probably an arming issue.)
[Image: ZPekDOil.jpg][Image: UuZpPhBl.jpg][Image: iP3tA0Il.jpg][Image: K0qNcQNl.jpg][Image: b6BxYVDl.jpg]
i know I'm an idiot. this is what i have. trying to connect but no luck
when in clean flight. in the reciever tab. i click on serial rx. i save it. but when you check what you have done in receiver the serial tab is empty again. I can't get it to stay highlighted
You should have one of your UARTs set to Serial RX in the Ports tab (usually UART 2 or UART 3).
[Image: bH6nxosl.png]
What is your flight controller, and where are your leads from Rx connected? (photo would be good)
And after that you go to the “Configuration” tab and scroll part of the way down. In “Receiver Mode”, select RX_SERIAL. In “Serial Receiver Provider”, select SPEKTRUM2048.Click “Save and Reboot”.
Thanks dude! Even found a YouTube vid. I'm almost there
Good to here that it's almost working, what did you changed?
  problems connecting and writing code for the remote (esp32) and the flight controller YarikVor 2 57 8 hours ago
Last Post: YarikVor
  Connecting IA10B receiver to SpeedyBee F4V4 Ladu 2 125 12-Mar-2024, 05:46 PM
Last Post: Ladu
  Connecting my new AVATAR walksnail Kit bar1 26 3,940 29-Aug-2023, 10:05 AM
Last Post: Lemonyleprosy
Exclamation RECEIVER NOT CONNECTING TO FLIGHT CONTR. ZATAROV18 0 180 06-Jun-2023, 10:51 AM
Last Post: ZATAROV18
Photo Connecting to FC takes me to CLI mode- Beta flight NoSkillAllLuck 3 234 25-Apr-2023, 04:58 AM
Last Post: matt0725
