TX Gimbals tensions
What's everyone's prefered TX Gimbals tensions?
Wanting to adjust the tension on my Taranis gimbals curious to know what everyone else prefers for each axis
Throttle/pitch/roll/yaw.
I like having them as loose as possible. I loosen them until they can't recenter and then back a bit. Remove the "clicks" on the throttle and then in firmware put yaw deadband around 10.
I have the right stick (mode 2) as loose as possible so that it still centers, on the left stick I have the yaw as tight as possible and throttle loose enough to hold its position.
Oscar's got a good tutorial on how to adjust gimbals: https://oscarliang.com/transmitter-gimba...aranis-tx/
I couldn't tighten mine enough so I replaced the gimbals with better ones. I dunno how anyone can fly with loose sticks
I have mine pretty stiff, I pinch my sticks and sometimes during a flight I'll have to readjust my grip so I'll let them go slightly and it helps me to know they are center when I grip them again.
I like firmer sticks also.
My youtube channel
I like my throttle loose to the point it barely holds position when let go. As for the rest of them, don't care really as long as they work reasonably smooth.
  New Product Boxer Max with cnc buttons,knobs and gimbals Rob3ddd 2 401 15-Nov-2023, 11:51 AM
  Help Gimbals slowly return to center jokhm 8 648 16-Mar-2023, 03:00 PM
  Solved Do Hall Sensor Gimbals Go Bad brettbrandon 2 599 24-Aug-2022, 10:30 PM
Last Post: brettbrandon
  Help Jumper T-Lite switches and gimbals not registering their movements Nwlongstreet 3 934 26-Sep-2021, 04:13 PM
Last Post: Nwlongstreet
  Help futaba t16sz with potless gimbals causing interferences with crossfire hugnosed_bat 1 1,907 27-Jan-2021, 02:48 AM
Last Post: the.ronin
