16-May-2017, 06:05 PM
As many of you have certainly already heard, HobbyKing recently launched the successor to their Mini Fabrikator 3D printer. I have been looking for a smaller printer for a while, so as soon as one turned up at the HobbyKing global warehouse, I put an order in!
I probably should have waited until they arrived at the EU warehouse. Even though they are cheaper from Hong Kong, the cost of DHL shipping brought it up to the same price as they are listed at in the EU warehouse and the fact that I got stung for 25% VAT plus charges from the Swedish customs service makes the final price around $250 including shipping.
Even so, for a fully assembled printer that has a hot end that will go all the way up to 250°C, has a heated bed, offline printing, filament cooling fan and a good quality, rigid construction, this is a good price!
The printer has a 100mm x 100mm bed and will print up to 100mm tall. While this is half the area of my Prusa i3 printer, many of the things I need to print for the RC hobby fit perfectly into the smaller print area of the Fabrikator.
Here it is set up on a cabinet beside my work bench:
This is a tiny little printer! It's 170mm wide, 182mm deep (or 240mm if you include the motor for the extruder) and 278mm tall, including the vibration dampening feet that it sits on.
Some more facts and figures: The heated bed only goes up to 60°C, which might present a problem if you want to print ABS, but the bed is also coated with a sheet of black PEI which gives excellent grip for PLA at least (which is all I've printed so far). Don't clean the print bed with acetone! It doesn't seem to damage the PEI, but it will remove the black pigment from it which is why my print bed has the white marks on it.
The printer is powered by an external power brick that delivers 12V at 7A and is connected to the mains with a standard three pin IEC plug. The brick works on anything from 100 - 240V, so if a Fabrikator with your choice of mains plug isn't listed, you can order one for any country and just replace the mains cable with one that matches your local mains socket. (I ordered one with a US plug and just threw the US mains lead away.)
The printer is designed for 1.75mm filament and has a 0.4mm diameter extruder nozzle.
The rear of the printer has an on/off switch and a socket for the 12V supply. There's also a slot for the included spool holder (more about that in a bit).
The right hand side of the printer has a micro USB socket, a microSD card socket and a control button.
If you place a g-code file named "auto00.g" in the root folder of the microSD card, insert the card into the printer and power it on, the button lights up orange. A single press of the button tells the printer to start printing the "auto00.g" file and the button will then turn blue to indicate that the print process has started.
The spool holder is a simple metal bracket that slots into the rear of the printer:
It sounds like a great idea! With your spool of filament on the rear of the printer, it keeps the width of the setup to a minimum.
Except there's a problem:
I don't know that size spools they designed this for, but my standard 1kg spool of PLA binds against the bottom of the extruder stepper motor which makes it useless for me. Thankfully, I had a spool holder from my Prusa i3 that could be used instead.
The printer comes with a 2GB microSD card which contains some (Windows) software and some test prints. The manual needs to be downloaded from HobbyKing. Also included on the card are some settings files that you can import into Cura to set the slicer up for the Fabrikator.
One excellent feature for the price is that the hot end includes a fan to cool the filament as it is extruded - something that's an essential for printing overhangs. The fan is fully software controlled so that it can be off for the first layer and then turned on at a variable speed for subsequent layers.
So far, so good!
There are some niggles...
Levelling the bed is a pain. Because the screws used to adjust the bed height are inside the frame, the rear ones are particularly difficult to get the supplied 2mm hex key into. This shouldn't have to be re-done too often, especially if you don't move the printer around.
There is no way to adjust the micro switches that are used to detect when each axis has reached the home position. This results in the head moving to a position slightly behind and to the left of the print bed when you home all axes:
This is reflected in objects that the slicer thinks are positioned in the centre of the bed being printed at a point that is actually further back and further left than the real centre. Some offset changes in the configuration should solve this and I'll post them when I've worked out what they should be.
I'm running the printer with Repetier Host and Cura on Linux. The printer does have a WiFi interface, which would make up for the fact that is no way to control the printer without connecting to it, but the only way to configure the printer's WiFi is via a Windows only program that won't work in a virtual machine because it needs access to the PC's WiFi interface to scan for available hot spots.
I have some PETG filament on order which I'll be testing with soon. I don't really want to print ABS as I live in an apartment and don't really have anywhere to put the printer where I won't be subjected to the fumes from ABS.
The other thing that needs to be tested is if the extruder will handle flexible filament. As the extruder uses a Bowden tube, it is very unlikely that it will print the softest flexible filaments, but I'm hoping it will handle the Ninja Semiflex that I have.
I've only had the printer for a day and there's some more fine tuning and testing to be done, but all in all, I'm pleased with it. As a budget printer for our kind of use, it's a good choice.
So far, so good!
