Hey! i don't get any commands from my 9xr pro, but its bound correctly i guess and the sbus receiver is getting data.
Any idea guys? Lg Thanks
Turnigy 9XR Pro OpenTX not transmitting? X4R SB + XJT |
Hey! i don't get any commands from my 9xr pro, but its bound correctly i guess and the sbus receiver is getting data. Any idea guys? Lg Thanks 27-Apr-2016, 01:41 AM What FC are you using? What serial port are you connected the RX to? did you correctly configure the port in Cleanflight? selected the correct RX type in configuration tab? 27-Apr-2016, 10:08 AM (27-Apr-2016, 01:41 AM)Oscar Wrote: What FC are you using? Yeah, i did! Finally i figured out that Sbus is not supported by OpenTx now. Back to er9sky original firmware it worked out. Set it to PXX and had 16 channels available |
Can I easily go from OpenTX 2. Version to older versions? | baevans11 | 4 | 91 | 9 hours ago Last Post: baevans11 | |
Tip & Trick FlySky i6X + OpenTX + ELRS + INAV screen | psicho100pro | 9 | 7,711 | 14-Apr-2024, 09:05 AM Last Post: psicho100pro | |
Solved Jumper T Pro - S2 switch shows as Pot in EdgeTX | maxer | 7 | 515 | 25-Dec-2023, 06:19 PM Last Post: Pathfinder075 | |
Tango 2 Pro Throttle Issue | TheFPVMoron | 10 | 1,155 | 01-Oct-2023, 11:40 AM Last Post: SnowLeopardFPV | |
Help TBS crossfire nano rx pro not working | Siins | 10 | 1,152 | 01-Aug-2023, 01:03 PM Last Post: Cake |
