Turnigy 9x with mods
[Image: Mready-01(1).jpg]
I was lucky to get Turnigy 9x reasonably cheap, already modded with backlight screen, and with pins for flashing firmware soldered in place.
It came with Orange Tx DSMX/DSM2 module, FrSky DJT Tx module and Turnigy Tx module and two (2!) turnigy 9X v2 receiver modules (which i managed to fry being impatient and brain-dead after 10 hours at work, and not alot of sleep Sad   )The fix should be relatively easy, and i'll make a guide on that one, if i manage to get it working Big Grin
It already has ER9X flashed on it, but I'll be flashing OpenTX, so that i can get into the groove for Taranish which i plan on getting at the end of the year.
Also, I'll be adding telemetry mod using the guides i found on these pages:
http://blog.oscarliang.net/turnigy-9x-advance-mod/
http://www.rchacker.com/projects/turnigy-9x
There were few small things needed fixing, with took all of 2 minutes and some creative thinking Smile
*Pro-tip: For cleaning sticky tape glue, use WD-40, it works like a charm.
Btw,I found Oscar's guide on this site, but there's no credit to Oscar or any other mention that he wrote it...
http://oddcopter.com/2012/08/15/flashing...ther-mods/
By the way.. There is mod on turning the 9x RX from PWM to PPM you might be interested hehe
http://blog.oscarliang.net/build-pwm-ppm...-receiver/
well, i have to fix them first Smile
but then i'll definitly give it a try Big Grin
  TX Ergonomic Turnigy Transmitter NoxNow 7 2,292 22-Aug-2016, 12:00 AM
Last Post: Bigjohn141
