Tuning Micro Brushless
Hey guys I just finished my 2nd micro brushless build
It flies very well with stock PIDs with the exception of some noticeable wobble (prop wash?) on hard turns and descending.
Setup:
F4+OSD micro FC (noname from banggood, has 16mb blackbox!)
Racerstar 1103 10000kV Motors
Racerstar 4-in-1 6A ESC
FuriousFPV 1935 4bladed props
Here's my blackbox logs
https://www.dropbox.com/s/9gn6et7scyuvwu...t.bfl?dl=0
Flight video
https://www.dropbox.com/s/p6bvptiva96rze...6.AVI?dl=0
CLI dump:
https://www.dropbox.com/s/chd1u17c58reyjq/cli_dump?dl=0
This is my 2nd build its nearly identical to the 1st with the exception of the FC (first has a F3), and the ESCs (1st uses individual ESC's rather than the 4-in-1), both fly about the same, I wanted to get the F4 with the blackbox to hopefully tune this one perfect that maybe i can apply similar effects to the 1st Wink
Thanks for any tips and help, These are my first brushless quads and my piloting skills have improved to the point that these oscillations are limiting what I can do.
  Rate tuning B4tn 3 399 24-May-2023, 05:02 PM
Last Post: Rob3ddd
  PID Tuning Guide Oscar 5 27,007 03-May-2023, 12:06 AM
  Help High Elevation Builds / Tuning blanco 1 551 21-Sep-2020, 03:26 AM
Last Post: blanco
  JST-SH Micro 1.0mm Male Connector? the.ronin 4 1,727 18-Jan-2020, 03:46 AM
Last Post: the.ronin
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,215 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
